Carrera controller
Carrera controller
Postby frank9129 » Sun Apr 23, 2017 5:29 pm
I was given a Carrera track.
I set up a bull ring and plugged everything in.
Nothing.
I have continuity between the power base and the lanes. The wall wart works when tested with a car. The only thing left is the controllers.
How do you test the controllers to tell if they are the problem? If I had three hands maybe I could test continuity. :violin:
HELP !! :bow-blue: :bow-blue:
frank9129
Re: Carrera controller
Postby 2FER SLOTS » Mon Apr 24, 2017 5:03 am
Analog ?
If they are red controllers polarity is important, check your power connection.
Clip your test leads to a couple of the controller terminals and activate the controller.
Brake and 1 won't do anything,brake and the other have continuity at rest,the two for speed control will vary resistance with actuation.
Digital?
Would take some research to find out how they work....sorry.
2FER SLOTS
Postby frank9129 » Mon Apr 24, 2017 7:43 pm
Yes, they are the red controllers.
I will give it a try tomorrow.
Thanks,
frank9129
Postby 2FER SLOTS » Tue Apr 25, 2017 5:19 am
The red Carrera controllers are electronic PWM.
The controllers themselves will only plug in one way, but the power connection can plug in either way.
The black controllers are resistor type and don't care.
2FER SLOTS
Postby frank9129 » Tue Apr 25, 2017 9:11 pm
I plugged the power cord + to +. Still nothing.
It should work. They are made to work.
There is always tomorrow.
Thanks
frank9129
Postby 2FER SLOTS » Wed Apr 26, 2017 5:03 am
If you jumper the two outer controller connections your car should have full power.
The center controller connection should be at 14.8 volts +/-.
Carrera is negative polarity. (the controller runs the negative side of the circuit).
What kind of cars ? Carrera digital won't run backwards on an analog track.
2FER SLOTS
Postby frank9129 » Thu Apr 27, 2017 7:31 pm
I have been a bit under the weather.
I am testing the track with a Carrera car.
Maybe tomorrow if the weather holds out.
Thanks
frank9129
