Page 1 of 2
Tire info
Fri Sep 08, 2017 8:05 pm
by vins123
I would like to know if there are any silicone tire for the new Carrera Capri Zakspeed?
Sylvain
Re: Tire info
Sat Sep 09, 2017 6:47 am
by mikeinclover
I keep meaning to look at it, I forgot to check when it first arrived at the store, I will check today and let you know.
Mike
Re: Tire info
Sat Sep 09, 2017 9:26 am
by vins123
thanks
Sylvain
Re: Tire info
Wed Sep 13, 2017 8:19 pm
by vins123
It will be for racing on a plastic track :D
Re: Tire info
Sun Nov 05, 2017 9:42 pm
by vins123
What it would be silicone tire forthe new Carrera Capri Zakspeed?
Quick slick and Super tire?
thanks
Sylvain
Re: Tire info
Mon Nov 06, 2017 12:48 pm
Both makes should work very well, There is a Super Tire for a Ford Capri (1309), I don't know if the Zakspeed uses the same tire. It would help if we knew the dimensions of the wheels, wheel diameter, wheel width, rib diameter, rib width and also the tire OD.
Re: Tire info
Mon Nov 06, 2017 5:05 pm
by Almafan 55
Quick Slick tires for that car is CB32,CB33,CB34,CB35. Cloverleaf or SCC should have them in stock!
Re: Tire info
Mon Nov 06, 2017 8:57 pm
by vins123
Re: Tire info
Mon Nov 06, 2017 9:23 pm
by Cincyslots
That’s strange, the sut 1309 should fit the M1 and the Capri.
Bruce
Re: Tire info
Tue Nov 07, 2017 5:24 am
by Almafan 55
Oops, sorry, I misread your post. I thought you had sideways Capri. Forgot that Carrera brought them out.
Re: Tire info
Wed Nov 15, 2017 4:58 pm
by vins123
is anybody tried Super tire silicone 1308 on the Capri, an answer will be apreciated
thanks
Sylvain
Re: Tire info
Wed Nov 15, 2017 7:33 pm
by Cincyslots
I have not but the 1309 is nearly perfect to perfect.
Bruce
Re: Tire info
Wed Nov 15, 2017 9:57 pm
by vins123
Re: Tire info
Thu Nov 16, 2017 11:18 am
by Cincyslots
Re: Tire info
Thu Nov 16, 2017 11:21 am
by Cincyslots
dang, I just saw you were after the Capri not the M1. I'll post more photos when I get more time.
