I disagree. And it isn't just the obvious scale issues all around. Which are the most glaring.
I read some comments about the "incredible detail".
Not sure anyone that knows this car can possibly say that. But hey, I am not a dealer trying to sell it. :angry-soapbox:
These gargantuan truck-sized tires are there for a REASON.
The reason is GROUND CLEARANCE or lack thereof.
There is slightly less than 1MM clearance between the chassis and track surface.
The only tire that I have that will work is the PG 22125.
And this is WITHOUT SANDING. For example, installing a 21125 to try and improve the appearance will result in the chassis bottoming out.
No silicones are tall enough (outer diameter) in my inventory.
Just a word of caution for those thinking about swapping tires.
Especially if you were wanting to install some smaller tires to improve the scale appeal.
In stock form it clears and works ok. Just be warned if you have severe overpass/bridge sections. But that is the case with others cars as well.
The other is the motor. Not because it is slimline, but because it tops out in the 28,000 RPM range.
I just do not see where this motor makes any sense. Simply too much, especially if you have a small to medium layout.
Making it a pretty much stand alone model with nothing else to match it with.
Unless you just have to have yet another MKIV, you might not want to invest.
