Home Racing World • View topic - Windshield smudges - ugh!
Postby Audi1 » Tue Oct 02, 2018 9:28 am
I just installed a windshield and two side windows on a car. I guess I was in a little bit of a rush to do it, because I now have some smudges on the inside of all 3 pieces. I was using CA glue to do the install so it is likely that the smudges are CA residue. Is there a way to get these “glass” pieces back to looking normal again or am I just stuck with the smudges....?
Re: Windshield smudges - ugh!
Postby kidvoltage » Tue Oct 02, 2018 9:40 am
That's never been successful for me, usually just makes a bigger mess. I switched to the glue the model airplane folks use for cockpits. Looks white, dries perfectly clear.
kidvoltage
Postby patwa » Tue Oct 02, 2018 9:41 am
Not sure if that is fixable. I was under the impression that CA will always haze the windows.
I have been told by the guy at my local hobby shop that only way to keep them clear is to use a white glue.
Testors has a product for that.
I have done the same before so I am also interested to see if it is repairable. Cheers
patwa
Postby mattb » Tue Oct 02, 2018 10:07 am
Probably stuck with it. About half of my builds end up that way. I got some of the new clear version of Gorilla Glue and it seems to really dry clear and not react with the plastic in any way. Not sure how strong the bond is, but time will tell. I have also used the watch crystal glue in the small white tube. It works pretty good , too, but maybe the bond isn't as strong. Neither dries very fast.
Postby mikeinclover » Tue Oct 02, 2018 10:11 am
It's a "racecar " Allan, put it on the track you will never see it going around the track.
Mike
mikeinclover
Postby Audi1 » Tue Oct 02, 2018 11:02 am
Now how do you know it’s a race car, Mike.....?
Postby RichD » Tue Oct 02, 2018 11:22 am
If you have a Dremel with a buffing wheel you may be able to remove the smudges with automotive buffing compound or even toothpaste.
Postby docdoom » Tue Oct 02, 2018 11:27 am
I have good results using the same stuff that you use to clean head lights lens. Mothers brand works the best
docdoom
Postby chrisguyw » Tue Oct 02, 2018 12:21 pm
As CA tends to attack styrene it is likely that the "smudges" are not only on the surface of the glass, but "into" the glass itself.
You can fix the problem by sanding the affected areas starting with 2000 thousand grit paper and working up to 8/12 thousand grit, then polishing compound, followed by a coat of Future/pledge...........it certainly can be done, but, it is a royal pain..........I only bother with this process on vintage cars where I have no access to clean/clear glass.
I would be careful if using a dremel........even at very slow speeds, it is easy to "burn" the glass (I became an expert on "burning" glass many years ago ;) )
A drivers net, drivers name, windshield shade, sponsor decals etc., over the smudges, while not the same as perfect glass, will be way way way easier.
Chris Walker
chrisguyw
Postby mikeinclover » Tue Oct 02, 2018 12:42 pm
mikeinclover
Postby HomeRacingWorld » Tue Oct 02, 2018 1:10 pm
How many times do we have to show this?
Stop using CA! :) :naughty:
Buy it. Use it. Life will change. :whistle:
Postby waaytoomuchintothis » Tue Oct 02, 2018 2:40 pm
Ditto. I have tried all the the available versions of the UV stuff, and they are all very acceptable. The particular one Harry pictured gives you a bit more of the liquid plastic than some of the others. There is one version of the stuff that has a small aluminum flashlight-style UV light, but that about the only difference from nearly all of the others, and they all work great.
Postby Brumos RSR » Tue Oct 02, 2018 4:07 pm
I now use testors clear parts cement after doing this car after car after car.
Brumos RSR
Postby Fletch3 » Wed Oct 03, 2018 5:27 am
I’m with Harry. I use BONDIC, and life did change! Even made extra mirrors with it. Great stuff!
Fletch3
Postby Ky.Slot Racer » Wed Oct 03, 2018 5:34 am
Ky.Slot Racer
HRW Master Modeler
