Removing Front Wheels from SRC Capri
Postby borninthe50s » Sun Sep 08, 2019 4:34 pm
I just got a new tire razor, and I'm going back and truing the wheels and tires on a few cars that really need it. I want to true the wheels and tires on an SRC Capri, but I cannot budge the plastic wheels on the front axle to get it off the car. I'm afraid if I use a couple of pliers I'll just wind up breaking the wheels. Is there a good way to do this? I have several cars with type of arrangement. Thanks in advance for the help. Glen
borninthe50s
Re: Removing Front Wheels from SRC Capri
Postby HomeRacingWorld » Sun Sep 08, 2019 4:46 pm
Well some will cut the chassis and then glue it back.
But, it's the way they are. They are likely cracked now...so twist and fix.
Postby borninthe50s » Sun Sep 08, 2019 5:01 pm
Had not thought about that. Thanks, Harry!
borninthe50s
Postby borninthe50s » Mon Sep 09, 2019 12:59 pm
Hadn't cracked'em yet. Cut out two small chassis pieces, removed the axle, trued up the fronts, put on some nail polish and glued the pieces back on. Worked like a charm. Thanks for the help, Harry! Glen
borninthe50s
