which gear
which gear
Postby hksk25 » Wed Sep 11, 2013 7:48 pm
Which Slotit sidewinder gear replaces the Fly Classics, 18mm or 19mm? Also is the stock tooth count 27? I want to maintain a 3-1 ratio so I will have to change pinion also? Why no 27 tooth count from them?
hksk25
Re: which gear
Postby HomeRacingWorld » Wed Sep 11, 2013 8:12 pm
19MM.
Stock gearing on Fly classics is 11/36
11 tooth pinion, 36 tooth spur.
Re: which gear
Postby RichD » Thu Sep 12, 2013 7:00 am
It probably would be best to change to a 12 tooth 6.5mm diameter pinion and use a Red 36 tooth 19mm diameter spur gear to get a 3:1 ratio.
