Home Racing World • View topic - reasonably priced complete rolling chassis?
Postby noddaz » Sat Sep 21, 2013 8:20 pm
Is there such a thing as a reasonably priced complete rolling chassis? I am thinking less than $25. If there is, from where...?
Scott
noddaz
Re: reasonably priced complete rolling chassis?
Postby dreinecke » Sat Sep 21, 2013 8:55 pm
I often use the PCS32 Chassis. Pendleslot has them under $25 typically and offer different styles of wheels. A bare one is cheaper yet, particularly if you plan on putting in your own motor and drivetrain. In the states, the chassis are available at Professor Motor.
Postby HomeRacingWorld » Sat Sep 21, 2013 9:58 pm
So being nosey, what are you wanting to build?
Postby frank9129 » Sat Sep 21, 2013 10:08 pm
Scott,
See if you can use the motor I gave you. You may have to gear it down a bit.
frank9129
Postby crossovercrazy » Sat Sep 21, 2013 11:04 pm
Professor Motor now has some Sebring rolling chassis (w/motor and Porsche 904 wheels) for $24.95
crossovercrazy
Postby Modlerbob » Sat Sep 21, 2013 11:14 pm
You can get the gslot rolling chassis with a body mounting system for right at $25. That is what I have under my 55 Chevy. It is very decent on wood with urethane tires but it is a bit weak in the braking department and doesn't leave much room for an interior.
Postby smithspeedway » Tue Sep 24, 2013 11:18 am
Thanks very much for the plug. We stopped carrying the Pioneer chassis. While the wheels and tires are beautiful, our guys are more racers than modelers. The Scaley is so fast and reliable out of the box, that the Pioneer cars quickly became obsolete.
Steve
smithspeedway
Postby noddaz » Sun Oct 13, 2013 5:44 pm
noddaz
Postby Nor Cal Mike » Sun Oct 13, 2013 6:19 pm
One place I find chassis occasionally is to simply search the term "chassis" in the 1/32 slot car section on Ebay. It will turn up all sorts of random chassis both rolling and not.
Postby dr fabio » Thu Apr 24, 2014 3:58 am
Inaslot sells Pioneer rolling chassis for less thasn $25 I think?? Check them out.
cheers
dr fabio
dr fabio
Postby noddaz » Thu Apr 24, 2014 5:41 am
Took a look there...
At current conversion it works out to about $27 each plus almost $8 shipping across the pond... Not too bad I guess. And better than others I have seen. Still not that magic under $25...
Scott
noddaz
Postby HomeRacingWorld » Thu Apr 24, 2014 6:09 am
Postby noddaz » Thu Apr 24, 2014 8:10 am
noddaz
Postby btaylor » Thu Apr 24, 2014 8:30 am
ebay has running gslot chassis for 19.95 or two for 37.00 fully adjustable it says good pictures and discription.
Postby noddaz » Thu Apr 24, 2014 12:27 pm
noddaz
