track jumpers
PostPosted: Thu Nov 21, 2013 11:10 am
by jjk
hi guys,when you install jumpers every 15 ft.does it go from track to track 15 ft or from main power source every 15 ft thank you :?: .
Re: track jumpers
PostPosted: Thu Nov 21, 2013 11:15 am
by nhdungeonracer
You can do it either way...
In most cases, the easiest way is to go from track to track.
Re: track jumpers
PostPosted: Thu Nov 21, 2013 11:40 am
Are we talking about plastic track? Wood tracks can go 40 feet without a power drop.
Re: track jumpers
PostPosted: Thu Nov 21, 2013 12:05 pm
by jjk
yes talking about plastic track,thankyou for your time jjk.
Re: track jumpers
PostPosted: Fri Nov 22, 2013 7:43 am
by Czar
When adding jumpers it is not the length of track that matters, it is the number of track joints. The track itself has very, very little resistance (resistance is why you use jumpers). It is the joints that introduce the resistance that robs you of even, consistent voltage around your circuit. You will be just fine if you place jumpers at every 15 - 20 track joints. So, a section that has several 1/4 or 1/2 track pieces will need a jumper in a shorter distance than if you have full size track pieces.
Re: track jumpers
PostPosted: Fri Nov 22, 2013 2:50 pm
by jjk
thank you very much for info,time to get wiring,jjk
Re: track jumpers
PostPosted: Fri Nov 22, 2013 4:13 pm
by RazorJon
what brand of track are you using?
Re: track jumpers
PostPosted: Sun Nov 24, 2013 2:09 pm
by jjk
razor im using scaly sport thanks jjk
Re: track jumpers
PostPosted: Fri Nov 29, 2013 4:51 pm
by oldtymer
jjk...I'm probably too late with my info , but I will throw it out there anyway just in case...I have a Carrera 1/24-1/32 digital layout with 81ft of track and I don't have any jumpers...I have the same voltage all the way around and don't have any problems with voltage lose while running 6 cars at once . Good luck with what you have going on .
Later , Fred
Re: track jumpers
PostPosted: Fri Nov 29, 2013 8:13 pm
by sidedraft
FYI, At around 60' our old Carrera 2 lane digital oval track had big power & amp drop offs per lane, the cars got slow, but, we are running big horse slot.it motors, now every 15 pc track sections or so we have jumpers on our now 90'+ track. Our next thing to purchase from cincy slots will be a dedicated power supply to go with 4 lanes & 8+ cars.
