by Cosmic Bilby » Sat Feb 08, 2014 1:18 pm
....All I did with mine was fit a Slot.it. Spur gear to get the gearing right....
I used the standard plastic pinion.
Also changed to a Slot.it. Motor, axles, hubs, guide etc.
It now runs quite well with my Slot.it. Group C's.
You guys do realise that when running with mag on plastic track the Stock Revell 83G would crap all over a stock Slot.it. dont you? :)
The 83G's weakness was its gearing (moonshot), subsequently braking action was weak as well.
A big diameter Slot.it. Spur will get acceptable mesh and gearing with the standard pinion and give you a magnet racers underdog to flog the Slot.it. cars with.....
