by Nor Cal Mike » Mon Apr 07, 2014 12:11 pm
All Slot.it wheels are insert type wheels. Slot.it makes nothing else.
I used to play with Artin cars a lot but it's been awhile so I am unsure of the exact axle dimension of Artin axles. I do recall the listing for NInco axles to be 2.48 mm. My best recollection is that the Artin wheels fit a little loose on Ninco axles. I can't tell you exactly which size bit to use but this is what I would do. To get the correct size, I would start by simply pressing the shank of a drill somewhere around 2.48mm into an Artin wheel If the fit is snug enough to securely hold the wheel, I would use that. Too loose, go up a size. Too tight, go down a size. My local Coast Hardware store carries unpackaged bits in a indexed display. It is easy to try different bits in the store before I buy.
