by paul gage » Sun Jun 08, 2014 9:40 am
Hmmm? Okay, confused. In laymans terms...
Are you testing the brakes or rolling resistance of the chassis. Wouldn't it be more precise to use an inclined surface and measure elapsed time over the fixed distance to measure rolling resistance?
If it's the brakes, most of the braking energy is created by the motor acting as a dynamo, not if it's free wheeling. If you taped/covered the one side, the circuit would be closed and the motor would not generate any electro-magnetic field, or what would also be friction in this application. The circuit needs to be open back to the controller's capacitor or what ever (not an electrical engineer) for there to be any draw.
Tire traction has a big impact here too. I would be guessing, however I'm confident saying the the tires convert 10 times the braking friction that the gears could possibly. The tires need to convert the rolling inertia into mechanical energy fed through the gears to the motor. Once the braking circuit is opened the motor generates its elctro-magnetic field which then acts as resistance which feeds back through the mechanicals as braking energy, further slowing the car. Provided of course the tires are hooked up.
I have always chosen gears by sound, less sound, less friction, that has always led me to smaller gears, 8/24 rather than 10/30. And, smaller gears fit in so many more RTR cars without cutting them all up.
What am I missing here?
