Home Racing World • View topic - Excuse my ignorance, but ...
Postby Reegs » Fri Aug 01, 2014 7:21 am
what exactly does the speed sensitivity control on, say, a PM controller do? I've only been using it for a few years and really have no idea how to use it! :oops:
Reegs
Re: Excuse my ignorance, but ...
Postby Florida_Slotter » Fri Aug 01, 2014 8:21 am
Reegs,
Hey there, no reason to think about ignorance, just unfamiliarty.
BTW - Welcome to Home Racing World. The best forum for slot cars that I know of.
While I do not have a PM controller, I do have several DiFalco controllers and they all have sensitivity controls on them. So, what do they do?
If you have ever driven a slot car with a controller that was either too high or too low in resistance, you would not be able to use the entire controller to adjust the speed of the car you were trying to drive.
The sensitivity control on the speed side will let you adjust the starting voltage for your car. Normally I will move the trigger so it is just off of the brake portion and on to the first spot that the car moves. I hold the trigger in this position and adjust the speed sensitivity so the car will move at a speed that will guarantee the car will make it around the most difficult turn on the track. Then when I'm racing, I know that I can simply go to that first position and the car will make it around any turn on the track.
Basically it lets you tune your controller to work with your cars. For those who race many different categories, you only need a single controller and that controller will work with all of your cars.
I hope this helps.
Postby sixtiesracer » Sat Aug 02, 2014 12:36 pm
I used a controller with that sensitivity dial for the first time the other night. Wow I couldn't believe how much smoother and faster I was driving!!! :auto-driving: :auto-driving:
sixtiesracer
The Rustinator
Postby Reegs » Sun Aug 03, 2014 5:58 am
Thanks, Marty.
BTW: I've been a member for quite some time. Just haven't had much to say! :dance:
Reegs
Postby Florida_Slotter » Sun Aug 03, 2014 6:32 am
