by Audi1 » Tue Aug 05, 2014 4:21 am
I ended up using Bob Smith Industries Super Gold Plus. It's a medium thick CA glue. I applied it with a very thin needle (my wife is a quilter and has some amazingly thin, long needles); dipped the needle into glue that I had squirted out onto a small plastic baggy and then applied it only to the thread surface inside the front body mounting post. I applied it very thinly and used 3 coats. Let it set up for 60 minutes and screwed the chassis to the body.
I wasn't satisfied; still not as much grip as I have in the rear.
So, I reapplied the Super Gold Plus; another 3 coats; let it set up for another hour and now I have a good bite on the front body mount; as good as the rear.
I'm thinking that, perhaps, the fact that I run the front body mounting screw looser than the rear, coupled with the fact that most of my deslots occur with front end impact, over time, causes wear and the lack of bite in the front mounting post.
So, I'm planning to keep my Super Gold Plus close at hand as I continue to race this car.
