by Nor Cal Mike » Sun Aug 10, 2014 9:39 am
I have been buying a lot of the bankruptcy liquidation sale SCX stuff on ebay for some time. I have bought quite a bit of it from Jimmswm and yes, he is very good to do business with. In fact, I was headed for his store when I bumped into this. He has a 4 car deal for $100 with free shipping and an even better deal for a dozen but I rarely can can afford to fork out that amount of cash on slot cars at any one time. But this deal coming in at $80 total shipped for four cars beats Jmms price by $20.00. I will have to see if it is worth the 20 bucks to go with an unknown seller. Ebay is a crap shoot in that way.
Bob, The Pro cars use a completely different motor. It is quick, too quick for the small Porsche, by RM's review. Unlike what Scalextric did with their Pro line, SCX uses the same sized axles as all of their other products. However they do use set screw gear and aluminum insert wheels all around. I have heard complaints that the aluminum is to soft and are easy to bend but I haven't had any trouble with them personally. They use a completely different chassis than the standard and use a screw in guide set up that is similar to Slot.it's. If you like magnets, you won't like the Pro cars because they come without magnets and there is no pocket to mount them too. They have a pod that is a bit different than the rest as it is designed to slit back and forth on acceler/ decelleration against a shoe that rubs on the crown gear for extra braking. I generallly run my tires as close to the fender openings so the backward and forward movement doesn't work for me. A dab of shoe goo at each front corner of the pod limits for and aft movement while still allowing some give in the pod.
As I said, I will kit bash these cars. I have a couple of C6 Corvette, (1 MPC model kit and 1 Fly) bodies looking for a chassis The will likely get 18k motors installed if they are meant to go on my road course. I also have come 3rd Gen Camaro model kits I have been saving up. They could become road cars or oval cars. If they wind up on my oval, I like my cars quicker so I will run a little hotter motor in them. Perhaps in the Slot.it orange bell range.
