Home Racing World • View topic - Camaro, revisited FINISHED!
Postby waaytoomuchintothis » Fri Aug 15, 2014 5:51 pm
Last edited by waaytoomuchintothis on Sun Aug 17, 2014 4:47 pm, edited 1 time in total.
Re: Camaro, revisited
Postby btaylor » Fri Aug 15, 2014 5:53 pm
Sure looks a lot better!
Postby BRP32 » Fri Aug 15, 2014 5:57 pm
I second that!
That is the way that car should of been built in the first place.....
BRP32
Postby scatman » Fri Aug 15, 2014 6:05 pm
Me like!!!
scatman
Postby FootScoot » Fri Aug 15, 2014 6:12 pm
Looks great Rob! Too bad Carrera didn't do it like that. I think I may have one of those bodies somewhere. :)
Postby waaytoomuchintothis » Fri Aug 15, 2014 6:26 pm
That's the chassis from a Sunoco Camaro by Scalextric. It took only about an hour to modify it to go under the car. The Sunoco chassis was part of a trade years ago, and was the first thing I set hands on for this project.
Postby Dundee Denny » Fri Aug 15, 2014 6:57 pm
1000% better!!!!!
Dundee Denny
Dundee Denny
Postby dreinecke » Fri Aug 15, 2014 7:14 pm
BINGO! Now, put that chassis on eBay and make some money!
Postby waaytoomuchintothis » Fri Aug 15, 2014 7:30 pm
I'm glad you mentioned that, David. The wheels are so oversized, they come very close to 1/25 scale. I have been thinking about using this under a small 1/25 hot rod model- maybe a T-bucket, all I need to make the illusion is some fat tires.
Postby HomeRacingWorld » Fri Aug 15, 2014 8:37 pm
Outstanding job. You really got'r done quick!
Postby Modlerbob » Sat Aug 16, 2014 5:11 am
Does the Carrera body/interior weigh much more than the one from Scaley?
Postby Jesla » Sat Aug 16, 2014 5:54 am
Jesla
Postby Fast Co. » Sat Aug 16, 2014 10:05 am
Nice work. Looks a whole lot better than the original.
Fast Co.
Postby waaytoomuchintothis » Sat Aug 16, 2014 10:24 am
I didn't care for the fake engine anyway, so I hacked it up to lower the body. The chassis screw holes actually line up pretty good in the rear, but up front you have to invent a post. The interior has to be cut out for the motor, but you cut it out in a spot that is almost invisible from above. Whoever had this chassis before had turned the front tires down enough to make the car a tripod, which I can't stand, so when I put normal tires up front, the stance and the body height just fell into place. This really was an easy conversion, and like I say, I had this chassis just laying around in the parts box, anyway. I disassembled the front end and outlined the parts with silver to make the details of the grill and headlights come out, and I took the numbers off the headlights. Carrera put little plugs in the fresh air scoops under the front bumper, which looked weird, so I popped them out and drilled the scoop holes open, which added a lot more than I thought to the looks of it. The body itself is very thick plastic, so there's plenty of room to thin out the inside of the fenders for tire clearance, which not only helps with lowering the body, it allows a wider stance for handling improvement.
Re: Camaro, revisited FINISHED!
Postby waaytoomuchintothis » Sun Aug 17, 2014 4:49 pm
