by Florida_Slotter » Sat Sep 20, 2014 11:49 am
First off, the motor that is supplied with all of the Sideways Group 5 cars is the Slot.It Flat-6 motor. From all that I have read, that motor is rated at 20,500 rpm. The Slot.It Flat-6R is rated @ 22,000 rpm and the Slot.it Flat-6RS is rated @ 25,000 rpm.
The choice of cars depends on the type of track you are running on. If the straights are short and the turns are of small radius, I might lean towards the Lancia. It has a pretty short wheelbase, which under normal conditions can be made to out handle a car with a longer wheelbase.
I have driven both the BMW and Capri variants of the Sideways products. Based on what I like in a slot car, I would lean towards the Capri as the car I would choose for the more sweeping turn layouts.
Whatever car you drive, I would more than likely go to a 1 or 2 tooth smaller spur gear. With all that torque coming out of a corner, the car could deslot. Sometimes having a lower numerical gear ratio will tame that issue.
Let us know what you choose and how it works for you.
