Carrera container arrival-Sept
Postby DaveKennedy » Mon Sep 22, 2014 7:43 am
They're unloading the container now i'm told!
A translation/description of each item on the new container
20030173 DIG 132 HYBRID POWER-new set-Porsche918 and Ferrari LaFerrari in this set
20030697 DIG 132 PORSCHE 918 S-new car-flat black with red trim
20030698 DIG 132 PORSCHE 918 S-new car-white “martini” decoration
20023795 DIG 124 MERCEDES BENZ-new car-flat black/silver/yellow decoration
20023799 DIG 124 AUDI R8 LMS "-new car-Carrera Safety Car
20023804 DIG 124 FERRARI 458 I-new car-red STP decoration
20025202 EV SPEED RECORD-new set-2 Porsche 911 RSR’s in this set-Gummi Bears and Yellow Racing decorations
20025206 EV POWER BOOST-new set - Porsche 918 and Ferrari LaFerrari in this set
20030585 DIG 132 DODGE CHARGER
20030604 DIG 132 DODGE CHARGER
20027377 EV DODGE CHARGER DAYT
20023789 DIG 124 FERRARI 512 S
20027467 EV PORSCHE 918 SPYDER
20023794 DIG 124 PORSCHE GT3 R
20020760 EX DIGITALTRAFO 18,0V-D124 power supply
20020588 EX/EV RANDSTREIFEN-1/3 shoulder border
20020589 EX/EV RANDSTREIFEN-1/4 shoulder border
20020590 EX/EV INNENRANDSTREIF-inner shoulder for 1/30 track
20020591 EX/EV INNENRANDSTREIF-inner shoulder for 2/30 track
20020594 EX/EV INNENRANDSTREIF-inner shoulder banked for 2/30 track
20020595 EX/EV INNENRANDSTREIF-inner shoulder banked for 3/30 track
20020596 EX/EV INNENRANDSTREIF-inner shoulder banked 4/15 track
20020601 EX/EV 2 STANDARDGERAD-2 pack of full-length straight pieces
20085202 EV/EX/DIG 132 STÜTZEN-adjustable support pieces for high banked track
20085203 EV/EX/DIG 132 STÜTZEN-support heads for track support pieces
20085204 EV/EXDIG 132 FAHRBAHN-track connection clips “C-shaped” –older style
20085205 EV/EX/DIG 132 METALLK-multi lane metal track connection clips-for securing tracks side-by-side
20085209 EV/EX/DIG 132 STECKZ.-track fasteners-for securing track to a table-these pegs slide into the sides of the track and you then use a screw through the hole to hold down the track
20085220 EX/EV/DIG 132 LEITPLA-track guard rail-3 meter length
20085245 EV/EX/DIG 132 FAHRBAH-track connection pegs-red “new style” pegs for securing track end-to-end
20085309 EX 2 SPEZIALLEITKIELE-special guide blade for track other than Carrera track-thinner, shorter guide and brushes in this package
20020709 EV HANDREGLER MECHAN.-EVO handthrottle-Analog thumb plunger controllers
20026713 EV TRANSFORMER USA-EVO power supply
20026732 EV DIGITALDECODER-standard digital chip
20026740 EV DIGITALDECODER-F1 style digital chip
20030350 DIG 124/132 ENGSTELLE-digital chicane-left hand lane
20030351 DIG 132/DIG 124 DIGIT-digital chicane-right hand lane
***note use both 30350/30351 together and you can make a 4-lane digital track!
20030353 DIG 132 DRIVER DISPLAY
20030355 DIG 132 LAP COUNTER-new style lap counter for use only with Control Unit
20030358 DIG 132 RANDSTREIFENA-1/2 half track length shoulder connection piece for use with Position tower/Start Light/Drivers Display
20030362 DIG 132 SPURWECHSELKU-corner lane change-left turn-inside to outside
20030365 DIG 132 SPURWECHSELKU-corner lane change-right turn outside to inside
20030367 DIG 132 DIGITAL SCHIE-30367 Digital Track Extension Set
Contents:
4 Standard Straights, each piece measures 13.58" (20509)
1 Double lane change section. Double lane change is made up of 2 pieces of straight track, each measures 13.58" (item 30347)
1 Lane change curve (right). Lane change curve is made up of 1 straight section (13.58") and 1 -1/60 curve (30365)
1 Lane change section (left). Lane change is made up of 2 pieces of straight track, each measures 13.58" (30343)
20089633 EV+DIG 132 REIFENSET-tires to fit ALL 599XX and 458 GT Italia racing decoration cars
20089637 EV+DIG 132 REIFENSET-tires for street versions (only) of the 458 Ferrari
20020516 EX/EV ENGSTELLE (2)-2 lane chicane section track piece-2 pieces of track in this box-2 lanes get closer and then back to normal width
20020517 EX/EV SPURWECHSEL (2)-lane change-lanes swap sides like an “X” for use with analog or digital-must be used in pairs in track system
20020551 EX/EV INNENRANDSTR.KU-inner shoulder (flat) 1/60 track piece
20020562 EX/EV AUßENRANDSTR.-outer shoulder 2/30 (flat) track piece
20020564 EX/EV AUßENRANDSTR.-outer shoulder-1/30 banked track
20020565 EX/EV AUßENRANDSTR.-outer shoulder-2/30 banked track
20020566 EX/EV AUßENRANDSTR.-outer shoulder-3/30 banked track
20020567 EX/EV AUßENRANDSTREIF-outer shoulder-1/30 (flat) track
20020568 EX AUSSENRANDSTREIFEN-outer shoulder – 4/15 (flat) track
20020569 EX INNENRANDSTREIFEN-inside shoulder – banked 1/30 track
20020579 EX/EV STEILKURVE 4/15-high banked track 4/15 track
20020718 EV/EX HANDREGLER-Exclusiv speed controller-for analog “Exclusiv” track system
20085372 EX/DIG 124 SCHWINGARM-D124 “rocker arm” guide arm for all cars except Hot Rods 2005 and newer
20085373 EX/DIG 124 SCHWINGARM-D124 “rocker arm” guide arm for Corvette GS/Ford GT40/Aston DBR9
20089108 EV SCHRAUBENSATZ-small body screws 2 sizes
20089200 EV/DIG 132 MOTOR E200-e200 standard motor-used in nearly every Carrera 1/32 scale car
20020584 EX/EV ZUSATZEINSPEISU-power cables 5 meter-power tap wires for ensuring good power around your track
20020585 EX/EV ZUSATZEINSPEISU-power cables 10 meter
20020365 DIG 124/EV SCHLEIFER-brushes D124/D132 fits all current cars
20020366 EX LEITKIELSET ab2006- brushes D124/D132 fits all current cars
20085201 EV/EX/DIG 132 STÜTZEN-track support legs-for supporting elevated track pieces
Re: Carrera container arrival-Sept
Postby HomeRacingWorld » Mon Sep 22, 2014 8:14 am
Unloading my entire order? Good news. :)
When you deliver it, free slotburgers for you.
Postby goosenapper » Mon Sep 22, 2014 8:57 am
Was ist das? Ich nicht sprechen Deutsch. Hast du eine liste auf Englisch, bitte?
Straying from my massacre of the German language, that list is impressive. I see a couple goodies that I've been waiting on.
goosenapper
Postby DaveKennedy » Mon Sep 22, 2014 9:38 am
Updated/translated
Ja, auf Englisch jetzt...meine Deusche ist sehr schlecht auch...
Postby KsRacer » Mon Sep 22, 2014 11:56 am
It's all Greek to me, LOL
KsRacer
