1.5mm pinion puller /press
Sun Oct 26, 2014 3:59 pm
by Audi1
I'm going to be running some FF-050 slimcan motors and I want to be able to change the pinion gears. Is there a good 1.5mm pinion puller/press; either as separate items or as a combined unit?
Re: 1.5mm pinion puller /press
Sun Oct 26, 2014 4:30 pm
by Ember
The Slot.it one offers options for both motor shaft sizes.
Sun Oct 26, 2014 4:48 pm
by Florida_Slotter
Sun Oct 26, 2014 6:16 pm
by Audi1
Hi Ember, I don't think that the Slot.It puller/press works for 1.5mm shafts. I have one and if it did, then that would be great.
I found one that Scaleauto makes; expensive, but it looks like it will do the job well.
Florida_Slotter, once I get the gear off, I may well go to the 2.0mm sleeve for the two reasons that you mentioned; thanks.
Sun Oct 26, 2014 6:23 pm
by Ember
They have some additional parts available for the Slot.it one Audi. The extras even allow for pressing pinions in situ (for those of us that solder a motor in place and realise there is no pinion on it)
Sun Oct 26, 2014 6:48 pm
by Florida_Slotter
Sun Oct 26, 2014 7:23 pm
by Audi1
Sun Oct 26, 2014 9:49 pm
by Ember
SP21 supposedly does 2.0 and 1.5 shafts. Check the barrel thing at the bottom. Trying to find the details on the Slot.it website.
Sun Oct 26, 2014 9:52 pm
by Ember
Mr Slotcar has one specifically for 1.5mm shaft. But I'm still sure the Slot.it one is supposed to deal with the 1.5mm as well.
Mon Oct 27, 2014 4:17 am
by mikeinclover
Tue Oct 28, 2014 4:09 am
by Audi1
Thanks for all the ideas/recommendations. I ordered the Scaleauto 1.5mm shaft gear puller.
Tue Oct 28, 2014 2:30 pm
by mikeinclover
Dave that is the same thing I posted above.
Mike
Tue Oct 28, 2014 2:42 pm
by Audi1
I didn't have a standard press. The only one that I have is the Slot.It gear puller/press and I didn't know whether or not that dual-ended screw worked in that unit. Otherwise, it looks like a great way to go.
