by cgingras » Sun Nov 30, 2014 11:11 am
The 5.5, 6.0, 6.5 and 6.75mm dimensions refer to the outside diameter of the pinion, measured from one end of a tooth to the end of the opposite tooth.
There are two motor shaft diameters. 2.0mm is the most used diameter and most short and long-can motors use 2.0mm motor shafts. When you get into the slimline motors, they usually have a 1.5mm motor shaft. There are now more 1.5mm pinions on the market but 2.0mm is the standard size of the center hole. There are some sleeves that you can buy to put onto a 1.5mm motor shaft to make it 2.0mm and you then have more choice when choosing a pinion.
5.5mm pinions are usually made for inline applications. When you go into sidewinder applications, things get a little more complicated. The standard is 6.5mm but it all depends on the distance between the rear axle and the motor shaft. Even Slot.it has had different distances in their cars and motor pods. Usually, if you're using a 18mm spur gear, you'll need a 6.5mm pinion. A 19mm spur gear will require a 5.5mm pinion. But there are exceptions to this rule, depends on which motor pod you're using.
You can see the valid combinations in a reference chart we've made, that you can download here (look for the notes at right):
slotitgearratiochart.pdf
Then, for anglewinder applications, you need to use a 6.5mm pinion, unless you're using a long hub anglewinder gear from Slot.it (this one requires special 6.75mm pinions). Again, some people like to play around those parts to get a different gear mesh that they prefer but you have the general idea here.
