Rounding Tire Edges
Re: Rounding Tire Edges
Postby Smokeio » Sat Dec 13, 2014 6:17 am
This really depends on your track, your track surface, and the amount of bite you have. The more bite you get and the higher your speeds, the more you need a rounded shoulder.
Smokeio
Postby HomeRacingWorld » Sat Dec 13, 2014 9:13 am
:text-yeahthat:
You always want a little. It is pretty important IMHO. I like to start with a slight amount and just test. Once the chatter is reduced I call it good enough.
Postby noddaz » Sat Dec 13, 2014 1:00 pm
I will go with the "round the edges" crowd. You need to round the edges just enough to get rid of the chatter. This calls for LOTs of testing to find out how much you rounding you need... Ok, maybe not so much. But it is a good excuse to "test" the cars...
Scott
noddaz
Postby Nor Cal Mike » Sat Dec 13, 2014 1:18 pm
Depends on the tire too. Softer tires require, more harder tires less. I generally give her plenty and call that good enough. You may lose a little bit of straight line contact patch in your tire when you round the edges but I doubt very much if you will find a measurable difference if you do a little more than necessary.
