H.O. Build-Super Modified
I started this build about 2 weeks ago but is still in it's beginning stages.
Took an old Hot Rod body and grafted the rear section of a Gran Prix racer to it. Had to put a gusset
piece in the back in order to mount it made from some sheet plastic. After it was tacked on the back
I use a mixture of old body plastic and Testors 3502 cement to fill everything in which not only is a filler
but also bonds the plastic together.
After drying, everything is sanded and low spots filled, I opened and filled the old wheel well openings. We then went
to work on the chassis. Chassis is a stock Aurora Magnatraction with all the do dads removed and sanded down smooth.
After the chassis prep, Body was checked for fit and the nose removed. New wheel openings were marked and opened up.
The nose was cut to fit and reattached in the same manner as the rear. The nose was then molded in and side bubbles removed.
The cockpit was also removed and the sides cut down some.
New side panels were then made and cut to fit and all seams filled and sanded.
Tools are fairly simple , an old Dremel lots of knifes and some homemade stuff. Sheet plastic, CA and goop.
One of the inside of how everything is put together.
This is where the build is right now. It's coming along, Still have to figure a way to mount it yet.
All for now
Kevin
All for now
Kevin
