QUestion
Forum rules
Open to ALL SCALES!
QUestion
Postby BARC 1 » Sun Jan 01, 2017 4:38 pm
Is this supposed to be a scratchbuild thing or are kit builds welcome too? There is the perception this is a scratchbuilding contest, and I am not sure if that is true.
Re: QUestion
Postby btaylor » Mon Jan 02, 2017 4:46 am
Dan, If the build will help anyone just starting in this hobby, then I would say go for it. Even the kit builds have there little obstacles that need to be addressed. My build uses over the counter parts and model kit, because I wanted a build that anyone could duplicate if they wanted.
Re: QUestion
Postby BARC 1 » Mon Jan 02, 2017 9:17 am
Thanks Bob.
Lloyd has a thread up on a 143 Porsche 911 and it uses a 3D printed chassis, and I felt it would fit in the build off thread, and you have confirmed it would. I will let him know
Re: QUestion
Postby LloydL » Mon Jan 02, 2017 6:14 pm
Yep, you got me, I will put something together on the 1/43 Porsche 911 build, thanks for the invite.
Regards, Lloyd.
LloydL
