Home Racing World • View topic - Peter..question
Peter..question
Re: Peter..question
Postby pfuetze » Wed Jul 17, 2013 3:40 am
Mike, IMPORTANT point: you can´t fit a magnet into my chassis!
What wheels / axles / tires / rubber do you want to use?
If i should make a suggestion, go to Ranch-Design, use a Fyrebox-2 motor (shorten the motor axle), 8 tooth brass pinion, 28 tooth Ranch-Design crown gear, front tires WDF17109 .395"x.187"x.094" Double Flange Wheel, rear tires WDF18089 .395"x.312"x.094" Double Flange Wheel, both with Low Profile Tires, .094" Dia. Axle. Get also some high flex guide wire from Steve. Desoldering braid from a hardware supply for braid.
you will need a .094" drill bit to drill out the axle holes in the printed chassis.
cheers,
Peter
p.s. did you think about trying a ranch-design inline kit chassis with rolling kit? got a magnet pocket!
Re: Peter..question
Postby OL Mike » Wed Jul 17, 2013 7:34 am
wheels 13/16 3/8 th wide are you looking at the the pic of trucks and how sets to ground the truck has a rubble thunder chassises made my Carrera go!! model Image Now this chassis works gooood wheels and all I got 2 tenco chassis new box. that I can use now why do I need a inline from R D ???
OL Mike
Re: Peter..question
Postby mgs75thmeu » Wed Jul 17, 2013 9:23 am
I'm sitting here in my deteriorating old mind listening to John Barleycorn on TVs classic rock channel, remembering how I used to be able to do drawings like Peter's(on paper with tools) when I was still in High School. Then I went in the Corps with plans of MIT when I got out. Never happened and John Barleycorn plays on....Keep up the good work Peter. Order for more chassis coming from me very soon!
mgs75thmeu
Re: Peter..question
Postby OL Mike » Wed Jul 17, 2013 3:50 pm
OL Mike
