Home Racing World • View topic - This blue print chassis
Re: This blue print chassis
Postby OldDogMotorsports » Tue Dec 17, 2013 6:33 pm
throw those damn wallwarts away and set a 12volt battery there to hook your track up to!,only thing I can figure is you`re pulling alot more amps than the wallwarts have!
OldDogMotorsports
Postby a110alpine » Tue Dec 17, 2013 10:37 pm
i am not getting any sound on you tube.
a110alpine
Postby Dodgefarmer » Tue Dec 17, 2013 11:09 pm
Mike from your video's it appears that you know the answer and HH is on the money. You need more amperage. Electrical power is measured in wattage. 1A x 1V =1W . ie 14.8V x 0.35A(350mA) = 5.18W. From appearances that is an SCE Firebox 1 and from the Robert Livingston motor List it requires 6.7-7.5W @12V = 558mA - 625mA . Try combining the walwart wires to a single terminal and that should give you 700mA.
Randy
Dodgefarmer
Re: AW: This blue print chassis
Postby pfuetze » Wed Dec 18, 2013 9:33 am
Why don't you just type the motor type instead of 8 minutes of video?
I'm quite good at reading english language but understanding spoken english is much harder.
So, please, can you name that motor?
If it is a fyrebox-1 from ranch-design try an artin wallwart and artin controllers, you got some. Does this gove you the same problem?
Postby OL Mike » Wed Dec 18, 2013 11:19 am
I don't know what type of motor this is fire or what Image Image Image http:/I put this blue print on my Carrera track it well not run with the The commercial wal port transformer and track controler that come in the box . I know for a fact that this motor will not run on my until I do some FFF modification To the track I M PUTTING OUT FACTS .to help out others so they don"t make the same >>>>mistake <<< :auto-checkeredflag:
OL Mike
Postby OldDogMotorsports » Wed Dec 18, 2013 11:29 am
OldDogMotorsports
Postby masmojo » Wed Dec 18, 2013 12:09 pm
O.K. I am thinking,that mike has already tested the motor and transformer! :teasing-blah:
In my experience it then has to be one of a couple/few things.
The chassis: it's not dragging the bottom is it? That motor may be just close enough to the track that the magnets pull the bottom down and it won't move????
The Wheels/Axles; they could be binding. with a small high speed motor sometimes they don't have enough torque to move the car if there is ANY binding.
The guide: You may have tested the motor, the transformer, etc. but there could be a simple disconnect in the system somewhere?
Lastly sometimes a blown motor will move when there is no load on it, but will not pull a load see if you can easily stop it by holding the shaft!?
it's gotta be sumpthin! :think:
masmojo
Postby OldDogMotorsports » Wed Dec 18, 2013 12:31 pm
OldDogMotorsports
Postby Cjent » Wed Dec 18, 2013 4:26 pm
Cjent
Postby OldDogMotorsports » Wed Dec 18, 2013 4:31 pm
OldDogMotorsports
Postby masmojo » Wed Dec 18, 2013 4:46 pm
One thing to consider Hoos is that this is basically a itty bitty HO motor and if it's needing that kind of power, there is probably something wrong with it!
If Mike has eliminated all the checkpoints I outlined above, then he should Sh*tcan that motor and use a different one!
masmojo
Postby OldDogMotorsports » Wed Dec 18, 2013 5:16 pm
OldDogMotorsports
Postby Dodgefarmer » Wed Dec 18, 2013 7:02 pm
Hoos I think yee be askin the wrong guy. Check out the 6th post
viewtopic.php?f=6&t=5073
Randy
Dodgefarmer
Postby OldDogMotorsports » Wed Dec 18, 2013 8:22 pm
OldDogMotorsports
Postby micyou03 » Thu Dec 19, 2013 8:19 am
I run my HO motors at 18-20 volts and they draw up to 2 amps when I accelerate. This is with traction magnets in the cars.
micyou03
