Home Racing World • View topic - Peter may need your help on this one
Re: Peter may need your help on this one
Postby pfuetze » Sat Apr 12, 2014 12:58 am
there are holes, but they need to be enlarged to the correct diameter. not enough precision from the 3D printers by now.
.085" and. 093" axles can be used.
you can even use brass tube as a metal bearing. I'm using 3mm outside diameter and 24th inside diameter for those.
Postby masmojo » Mon Apr 21, 2014 9:08 am
Well, I just placed my order for the chassis!! Very Excited to see how they come out!!??
I bought about 11 chassis, 7 of yours and 4 of Datto's; that should keep the Racing shop busy for some time!
:text-thankyouyellow:
masmojo
Postby pfuetze » Mon Apr 21, 2014 2:18 pm
thanks, Mas!
What will you do with the Trabant chassis???
it´s basically the same as the one for the Mini, only a little longer wheelbase.
Postby masmojo » Mon Apr 21, 2014 2:57 pm
masmojo
Postby pfuetze » Tue Apr 22, 2014 12:54 am
for the FF030 sized motors, you can choose between the motorpod chassis and the GRC chassis.
