Re: what´s on your bench right now? [1/43]
Postby taskak » Sat Apr 28, 2018 8:24 am
taskak
Postby LloydL » Sat Apr 28, 2018 9:48 am
Very nice work as always Aki!
Regards, Lloyd.
LloydL
Postby BARC 1 » Wed May 02, 2018 8:54 pm
Lloyd , When is the Gaydon show?
Postby LloydL » Sun May 13, 2018 1:12 am
So sorry Dan, I missed this post! It is next Saturday and Sunday, the 19th and 20th.
Regards, Lloyd.
LloydL
Postby BARC 1 » Sun May 13, 2018 8:06 am
I was asleep at the switch this year, so sorry, but looks like I have missed the window.
Postby LloydL » Mon May 14, 2018 1:58 am
No problem Dan, there is always next year........probably!
Regards, Lloyd.
LloydL
Postby pfuetze » Mon Jun 11, 2018 10:43 am
started with the works for the Little Monte Proxy
first - changing the guide - the standard new style SCX braid did not work to tell or at all at my track - so in goes a SlideGuide ...
cutting free the front area to give space for the cables
soldering the high flexible silicone wire to the copper strips
a little drop of super glue on the axles near the bearings to minimize the alxe play
shortening the front axle to remove side to side play
​glueing the tires with CA to the rims
sanding the tires
sealing the front tires with CA glue​
a little work on the ride height may have happened ...
voila ....​
front tire trueing: the rubber round drives one wheel while the other one is sanded
​img]http://www.homeracingworld.us/SHADOW/Coppermine/albums/userpics/10033/werkbank116.jpg[/img]
the screw-plug of the CA bottle is glued to the bottle. glue is still good, so a little cut on the side to drip out the good stuff.
heals itself ;-)​
a little work in the process of building a racing mini ...
roof section has been in 4 pieces
roof is dropped so it had to be wider and longer
shortened all 6 pillars
removed the side windows from the carrera body to get vac-forming plug, also the rear window
opened the front air openigs in the body
Postby pfuetze » Mon Jun 18, 2018 9:55 am
and another project is started while other ones are not finished.
there is a race - "beetle cup" in september in Hamburg.
For the Little Monte Proxy, the decision fell to built a Mini, but the body works for the Beetle are little more challeging. As i could not make up my mind what the beetle should look like, decision fell to build a racing one :) - flared and low.
still much work to do ...
Postby pfuetze » Mon Jun 25, 2018 2:12 pm
the beetle had its share of filling, sanding, filling, sanding, filling and sanding again.
and again
and again...
but i think it looks quite good now. good enough for a racer :)
started also with the Mini for the Little Monte Proxy - it will be the #7 from 1968.
got the additional lights from a guy in the german go! forum - many thanks to Dusan.
had the chassis and the wheel inserts lying aroung, so the chassis is ready, only tires need sanding. using the Ranch wheels and crown that have been lying around for too long. good stuff.
cheers!
Postby taskak » Mon Jul 02, 2018 11:04 am
Not a big beetle fan but that looks like a beast :D
taskak
Postby LloydL » Mon Jul 02, 2018 11:20 am
Do I see a Special Saloon proxy in the future?
Regards, Lloyd.
LloydL
Postby pfuetze » Tue Jul 03, 2018 12:40 am
this could be a good idea, Lloyd!
i feel a special saloon Mini and a Fiat 500 :D
Postby pfuetze » Wed Jul 04, 2018 12:56 pm
errected the scaffolding in the back of the Mini ;)
also color is chosen and paint goes on ...
Postby pfuetze » Mon Jul 09, 2018 1:53 pm
started works for a Renault R5 Turbo for the Little Monte Proxy ....
Postby LloydL » Tue Jul 10, 2018 3:54 pm
Scaffolding?
Regards, Lloyd.
LloydL
