Home Racing World • View topic - Pinion puller
Pinion puller
Pinion puller
Postby MichiganCur » Thu Apr 09, 2015 5:23 pm
Is there a good puller and pressfor our cars? Seems my old 130 / 180 sized one has grown legs.
Thanks
MichiganCur
Re: Pinion puller
Postby Broman62 » Thu Apr 09, 2015 7:47 pm
Re: Pinion puller
Postby Dodgefarmer » Thu Apr 09, 2015 8:11 pm
Wow! My memory actually worked when I wanted it to for once. Check the 5th post.
viewtopic.php?f=6&t=378
Although I couldn't seem to find it there. Maybe pm Cjent.
HTH
Randy
Dodgefarmer
Re: Pinion puller
Postby MichiganCur » Thu Apr 09, 2015 9:40 pm
Thank broman I'll keep that in mind
Dodge, the one shown on that post doesn't come up with a search on tower hobbies site, only thing that comes up looks a lot like my Parma one where the pin is too big so it's useless on the smaller shaft motors...
MichiganCur
Re: Pinion puller
Postby Cjent » Fri Apr 10, 2015 9:12 am
This list was done several years ago. I still have the puller and it fits 030 motors, but I can't say it is still available after this long.
Cjent
Re: Pinion puller
Postby Dodgefarmer » Fri Apr 10, 2015 9:17 am
Hi Chuck. Could you post make and model (PN if available) and maybe we could do a search that way.
Thanks
Randy
Dodgefarmer
Re: Pinion puller
Postby walker » Fri Apr 10, 2015 1:16 pm
walker
Re: Pinion puller
Postby MichiganCur » Fri Apr 10, 2015 7:10 pm
Awesome, I found a motor tools kit that had one in it... But for $80 I would rather dremel off the worm gear and pullies currently on them.... But with that eBay one I'll be able to save them :-D (that was the only link to work)
MichiganCur
Re: Pinion puller
Postby walker » Sat Apr 11, 2015 9:39 am
walker
Re: Pinion puller
Postby Cjent » Sat Apr 11, 2015 11:52 am
Cjent
Re: Pinion puller Hold the Presses (er, Pullers)
Postby Cjent » Sat Apr 11, 2015 12:05 pm
Here it is!
http://www3.towerhobbies.com/cgi-bin/wt ... LXHHN2&P=7
But... it says discontinued at Tower Hobbies............................ :o
Cjent
Re: Pinion puller
Postby Cjent » Sat Apr 11, 2015 12:12 pm
Cjent
Re: Pinion puller
Postby MichiganCur » Sat Apr 11, 2015 10:01 pm
Nice thanks
MichiganCur
Re: Pinion puller
Postby munter » Sun Apr 12, 2015 4:25 am
It says "Out of stock" on my link....I bought one of these on eBay but believe that MrSlotcar produces a puller with the 1.5mm shaft option.
As a make shift idea it shouldnt be too hard to modify the shaft on a Parma puller.
