Home Racing World • View topic - Hogging out window techniques?
PostPosted: Sun Dec 04, 2016 2:15 pm
by nerfbarz
Re: Hogging out window techniques?
PostPosted: Sun Dec 04, 2016 3:15 pm
Dremel and milling bit. Fine tune angles with small file.
PostPosted: Sun Dec 04, 2016 5:59 pm
by BARC 1
Nice find. You could almost leave the windows in the Van and only remove the glass in the cab. As Harry mentioned I would use a dremel with care and then use a file
PostPosted: Sun Dec 04, 2016 6:51 pm
by nerfbarz
All good ideas!
Thanks,
Nerf
PostPosted: Mon Dec 05, 2016 1:10 am
by pfuetze
drill bit, multiple holes, file afterwards ...
much work stay, however you do it...
for a nice and clean result, small files are the way to go i think.
PostPosted: Mon Dec 05, 2016 7:37 am
by studioRS
Least intrusive method I use is to heat up a #11 xacto blade and use the normal sharp side. Like a hot knife through butter.
