by masmojo » Thu Jan 10, 2013 11:15 am
Peter/Lib, I am not sure where I got the Low Profile tires I have? I thought I got them from Ranch, but it's been a while back and they came with some wheels (I think? & also I think the wheels had the same shape as the SCX wheels??? Because the tires were interchangeable, BUT I could be confused on this because I got them a couple years ago and only just started running them???)
I really tought I would prefer a wheel profile like those of the SCX & Carrera (& 99% of the 1/32 cars out there) but after running some of the low profile replacement tires I am not so sure.??? As I said I prefer the "look" and those wheels are definately easier to fit inserts in, BUT most of the cars I like and want to build are older Vintage cars which have a much higher profile tire anyways. I think that even if the Shore on the taller tires is the same it has more grip then the low profile (at least in 1/43 scale cars) Or seems to. The main distraction for me on the older Ranch wheels is there seems to be only a few sizes of tire and when I have ordered the smallest size wheel, the tires seem a little loose and as Lib mentions the sidewall profiles are kind of non-existant and not very convicing visually. The other advantage of the wheel with the center ridge is being able to get a realisitic look even in the smaller scale cars & I do like that!
Also Peter, yes the Low profile tires require less sanding, BUT on the flip side you can't sand them too much or there's nothing left!, Conversely, I have been able to get a slightly too large wheel/tire combo to fit on the old Ranch wheels, by simply sanding the tire a bunch.
What's the ultimate solution? Heck I have no idea! ;-)
