Peter´s cars ...
Peter´s cars ...
Postby pfuetze » Sat Sep 15, 2018 6:17 am
First car to be presented:
Artin Nastruck - repaint, rechassised ....
started life as an Artin NasTruck.
a little paint, some decals, vac-formed clear windows
3D printed chassis with motorpod, silicone dampers between front part and motorpod.
Re: Artin Nastruck - repaint, rechassised ....
Postby TuscoTodd » Sat Sep 15, 2018 9:07 am
Great looking conversion sir! Looks ready to carve the corners!
:handgestures-thumbup:
Lancia Delta HF Integrale
Postby pfuetze » Sat Sep 15, 2018 11:58 am
Dnano body on scratchbuilt chassis
2mm axles, ball bearings, printed guide and wheels, CarGo high grip tires, high flex silicone cables for pickup
Re: Peter´s cars ...
Postby ourwayband » Sun Sep 16, 2018 2:03 pm
Great looking builds!!!!!!!!!!!
Postby nerfbarz » Fri Oct 12, 2018 3:15 pm
Nice work!
Nerf
nerfbarz
MINI´s (italian job ...)
Postby pfuetze » Sun Nov 11, 2018 12:50 pm
and again some Minis ...
i always wanted "Italian Job" Minis in 1/43.
these are my version of those cars.
printed chassis with printed wheels and printed guide, from shapeways
ball bearings with 2.38mm axle
high flexible silicone wires for pickup
modified heller kit body, lowered, flared wheel arches by me, re-casted in resin by Tilo 3 times
vac-formed interior
driver figures from vroom
Postby taskak » Sun Nov 11, 2018 2:47 pm
Great looking Mini's Peter, all you need now is to build a bus :D
taskak
Postby LloydL » Sun Nov 11, 2018 3:02 pm
More marvelous minis!
The weather is always so nice on your grid!
Regards, Lloyd.
LloydL
Postby pfuetze » Wed Jan 09, 2019 3:03 am
The red Mini Pickup was finished some time ago, now the blue and the white Pickup finish the Trio.
Pickup body has been made out of 2 Heller kits, also widened the wheel wells a little.
here some pics:
Postby LloydL » Wed Jan 09, 2019 8:37 am
:o :o :o
Regards, Lloyd
LloydL
Postby taskak » Thu Jan 10, 2019 3:10 am
Really good looking Pickups Peter, nice job! :clap:
taskak
Postby masmojo » Fri Jan 25, 2019 1:26 pm
Those look Clean! Nice Blue!
masmojo
Postby pfuetze » Sun Apr 14, 2019 8:35 am
Vac-formed Lotus Exige body, 0.5mm PETG
2 chassis for the same body, one with a 1.5mm polystyrene chassis plate, one with a 1mm brass plate
2.38mm axles, printed wheels, printed motor holder and guide holder, printed guide
fixed with 1.4mm screws
body painted from the inside with Revell aquacolor colors, homeprinted decals applied from the outside, fixed with clear revell aquacolor.
running on the smooth surface of the Desmo, the light plastic chassis is handling way better than the heavy brass chassis. not too much difference in the laptimes, right now, there are only 0,3secondes difference in laptimes, 9,4 for the plastic, 9,7 for the brass. both could need some tuning, but now it´s time to run this little car like there is no tomorrow!
Postby BARC 1 » Sun Apr 14, 2019 9:47 am
Nice!!
Really good looking cars, with solid chassis design. Looks like they can all run fast.
Postby pfuetze » Fri Apr 26, 2019 10:07 am
Porsche 356 - paint & decals by Tilo (dillerman2)
the is a really tiny car, it´s closer to an Austin Mini than to any other car...
runs nice and smooth.
and yes, on the first pictures it shows that the chassis is not set up 100% by now as the front wheel is lifting ;-)
