Home Racing World • View topic - ARTIN wireless super loop express.
Postby OL Mike » Sun May 05, 2013 10:32 pm
ImageImage[ This week I bought a ARTIN wireless super loop express. It set me back 50 bucks. I got it at At K MART. It has a continuous 8 volts of power running to the track.The cars are control with a Infra red transmitter looks like ray gun a trigger It runs good The draw back is they don't have big enough track the cars a detailed and run fast. I think that they did a out standing job on this track Its a hoot to run Image
OL Mike
Re: ARTIN wireless super loop express.
Postby pfuetze » Mon May 06, 2013 12:28 am
wheels are a little to big on the Porsche, but the old body still looks good!
The infrared receivers are in the cars or inside the track power piece?
Postby Cjent » Mon May 06, 2013 7:00 am
Interesting!
Cjent
Postby OL Mike » Mon May 06, 2013 4:14 pm
ImageImageImage So her's where I'm at with ARTIN I took it out box just set up and then I gave it test run with no loops (( I DON'T LIKE LOOPS)) The cars stay on track real well. After I played with it for awhile. I then I took it to my shop to give it real good looking over if going talk don't think it is a good idle to no the product inside and out. So far I like what I see. The first thing is the wheel.they have nice rims a clean look wide rubber tires on back thins rubber on front. The body is well detailed .on top of car's chassis set the receiver this get its power from the track Lots of possible Ideals I think the car need a fine tuning 2.The track's wall-port 8. 4 VOLTSI running into plug a black and red wire run to both lanes. The controller looks like array gun it takes 3 triple A batteries to run it you point and pull the trigger and the car the goes I found one flaw the nose of gun is suppose to light up when you pull the trigger I ran this car on my Carrera track it ran real good
OL Mike
Postby pfuetze » Mon May 06, 2013 11:50 pm
thanks for the pics, OlMike!
so, the electronics are inside the car, just like a digital car.
I don´t think that the nose of the controller should light up, this is the Infrared diode that sends out the control impulses to the car! No light, just IR.
Postby Broman62 » Wed May 08, 2013 6:45 pm
Postby masmojo » Thu May 09, 2013 6:16 am
Good to see; I was wondering about this set and whether the remote could be hooked up to my track? I could not find a Kmart by me! Typical Artin they screwed this up by putting the remote in the cars!!! If they had put it in the track interface, you could move it from one track to another and use a variety of cars??? Oh well, Mike saved me some money!!
masmojo
Postby OL Mike » Thu May 09, 2013 11:13 am
]Infrared (IR) light is a wavelength of energy that is invisible to the human eye. The most common source of this energy is heat; objects can have their relative temperatures measured by how much of this energy they give off. Lower wavelengths or "near infrared" — closest to the visible light color red — are not hot, and are often used to transmit data in electronics. A remote control, for example, may use a particular wavelength of near infrared to communicate with a receiver, sending pulses of light that transmit a signal to the device, telling it what to do. this how the car work Imageworks this car
OL Mike
