Home Racing World • View topic - Peter..question
Page 1 of 2
Peter..question
PostPosted: Fri Jul 12, 2013 6:57 am
by Derby City Speedway
Peter, is there anything in your line up that may fit this layout ?
Re: Peter..question
PostPosted: Fri Jul 12, 2013 12:19 pm
by pfuetze
Mark, no problem, i can make it fit. What motor do you want to use? H0 style boxer motor? Motor pod chassis or fixed type of chassis?
Re: Peter..question
PostPosted: Fri Jul 12, 2013 3:57 pm
Wouldn`t mind have 2 types, SCX ff030 motor, and the HO square motor, so maybe both in pod type ? :dance:
Re: Peter..question
PostPosted: Sat Jul 13, 2013 9:14 am
by pfuetze
Hi Mark, no problem with the 2 types. I would need 2 measurements:
wire guide like the SlideGuide or Braid type guide?
Which size of wheels are going to use - this influences the guide height?
Re: Peter..question
PostPosted: Mon Jul 15, 2013 1:30 pm
466"x.250"x.094" R/D
466"x.312"x.094" R/D
Rear measurement is 1"
Front measurement is 1-1/16"
Braid type guide
Re: Peter..question
PostPosted: Tue Jul 16, 2013 12:45 am
by pfuetze
Mark, on the front, the guide will protude in fully pivoted position by app. 1mm (1/2" = 12,7mm), but this is measured from the plain of the middle of the front axle and your measurement with the 1/2" is starting from the guide stem middle.
what measurement did you guess from the middle of the front axle to the middle of the guide stem?
here are 2 pictures of the chassis right now, i think it should be possible to stay within your specs :)
the chassis are already on shapeways with your measurements.
Re: Peter..question
PostPosted: Tue Jul 16, 2013 6:52 am
Re: Peter..question
PostPosted: Tue Jul 16, 2013 8:22 am
question, are we close to the 3-1/16 " from rear chassis to front of braid guide?
Re: Peter..question
PostPosted: Tue Jul 16, 2013 9:55 am
by OL Mike
Peter do you have chassis for sale ? I like what see
Re: Peter..question
PostPosted: Tue Jul 16, 2013 12:48 pm
by pfuetze
Re: Peter..question
PostPosted: Tue Jul 16, 2013 3:31 pm
by OL Mike
ImageCan I send you the body of this truck It looks good on the
Re: Peter..question
PostPosted: Tue Jul 16, 2013 7:11 pm
It's for a 917 pink pig Peter, it's a diecast right now. But if I can make all this work, I plan on casting it. I'll order a couple of each tomorrow after I get up. They look super thanks again.?
Re: Peter..question
PostPosted: Tue Jul 16, 2013 11:24 pm
by OL Mike
Image]I did my best to make look wright
Re: Peter..question
PostPosted: Tue Jul 16, 2013 11:37 pm
by pfuetze
Mark, i was wondering about the dimensions. But pink pig is the explanation :D
You´re welcome on the chassis, please let me know what you think of them.
@olmike: sending that body across the pond only for measurements would be expensive fun, ey? Which motor do you prefer? Boxer motor or FF-style? After i get this information, i will customize your chassis.
Re: Peter..question
PostPosted: Wed Jul 17, 2013 12:40 am
by OL Mike
Image The truck on the left and right has Rebel thunder GO!! chassis 4 1/4 long see how far up in body they sit almost 2/8 th the wheel set just under the flair of finder the body set close to ground I don't no a thing about boxer motor you tell me what would be best
