Home Racing World • View topic - BROADSPEED MINI / HORNET FIRST TEST SHOTS
Postby transam6870 » Sat Sep 07, 2013 8:41 pm
hey guys
I came across some pics of this car and decided I had to build one. . . or 3 :D . I just didn't realize how frickin tiny an actual mini is until the Heller kits arrived. I would hate to see an HO scale version of this thing but they are cool little cars. got a couple of Peters mini chassis which are awesome, and we are off. so here is what I am after ( in street trim) and then my progress so far, its just getting to the ugly part of the build :lol:
transam6870
Re: BROADSPEED MINI GT
Postby pfuetze » Sun Sep 08, 2013 1:28 am
great work so far, Mickey!
you know that you´ll have to cast additional bodies to send them over the pond? I like your work on that great little car!
Postby transam6870 » Sun Sep 08, 2013 9:27 pm
I figured you would probably want a couple Peter, glad to send them. got a little work done it. smoothing out the back end and started on the flares. I need to get the other mini started and get the other running mate going too. I will reveal that one later. you will like it too Peter. I will need to get a couple more of your chassis'
transam6870
Postby pfuetze » Mon Sep 09, 2013 2:49 am
let me guess - a Mini Marcos? :D
i already like the work you´ve done to the GT!
what i wish - that i would have sent the flared Mini (now red with white stripe) to get it casted before i painted it! Now i need to do that fender flare job again, plus the lowering of the body before. I can remember only to well how long it took to get it smooth. silly me (again). But hey, it´s part of the fun as well!
looking forward to see more!
i need chassis, wheel inserts and from Ranch-Design 2 pairs of the Marchon H0 Jeep wheels, just like the ones already used. Set screw wheels with a set screw crown make adjustments to the rear axle so easy that i won´t miss them.
And tires - but these are already ordered from CarGo.
keep up your great work and thanks for it in advance :D
Postby Cjent » Mon Sep 09, 2013 6:05 am
That is COOL, TA!
Cjent
Postby transam6870 » Mon Sep 09, 2013 8:01 pm
hey guys
Peter your flares look awesome. you might try some 3/32 quarter round styrene wrapped around a 7/16 inch dowel. they came out perfect and none of that drying,sanding,drying,sanding. i have to shape a little on the front flares and they are done. as soon as i am happy with the rear quarter panels the rear flares are ready to go on.
and no Peter its not a Marcos, a Wolsely Hornet/Riley Elf. this is what i envisioned zipping around my track
transam6870
Postby dreinecke » Mon Sep 09, 2013 9:17 pm
That is alot of work so far. Nice job! What are you using on the wheel arches?
Postby transam6870 » Mon Sep 09, 2013 9:24 pm
David i am using 3/32 quarter round styrene wrapped around a 7/16 dowel and glued to form a loop so as to hold its shape while being glued to the car and then trim off the excess. there is a pic above and its actually a large exacto handle. fit the mini wheel arches perfectiy
transam6870
Postby dreinecke » Mon Sep 09, 2013 9:26 pm
Brilliant. I've done that before but thought in one pic it looked like it was flexible and that's why I asked. Nice stuff!
Postby pfuetze » Tue Sep 10, 2013 2:13 am
thanks for the flowers Mickey! the tip with the 3/32 quarter round styrene is good - will try to locate some!
would be an easier and faster way to get the flares and they look awesome, too! big thumbsup!
Postby transam6870 » Wed Sep 11, 2013 10:05 pm
hey guys
got the flares done, i will see what they look like after a coat of primer. now to finish blending in the roof and rear deck area, clip the wing and finish the rear panel and bumper
transam6870
Postby pfuetze » Thu Sep 12, 2013 12:26 am
the flares look great, so does the rear end! it will look great, Mickey!
Postby dreinecke » Thu Sep 12, 2013 6:14 am
I think you've nailed it!
Postby Broman62 » Sat Sep 14, 2013 6:20 am
Postby Wolseley Hornet » Sat Sep 14, 2013 11:53 am
What an achievement! This would have been fiddly enough in 1/32!
I almost hate to say it, but you might want to get a front view of a Broadspeed Mini.I've just got a feeling that the grille wasn't as heavy as the Rover Mini grille.
David.
Wolseley Hornet
