legends of racing ford make over time.. help please
Postby a110alpine » Thu Nov 07, 2013 3:33 pm
i now have in my possession the lorenzen ford... a beautiful white it is and i would like to keep it that way... the blue tampo comes off and gurney decals go on. has anyone in hrw successfully removed the printing on these resin classics with out damaging the paint.. ??? my inquiring mind would like to know.. thank you in advance..
a110alpine
Re: legends of racing ford make over time.. help please
Postby masmojo » Thu Nov 07, 2013 4:05 pm
I have removed tampo on a couple cars, but not the Legends cars; Here's what has worked for me in the past in order of desireability
1ST - Tape, YES Tape! A good sticky masking tape, stick it to the tampo, burnish it in real good with your fingernail and the pull it off!!, Be patient it might take 8+ Pulls to see any measureable result. If after 8 good pulls you don't notice any difference, then go to option #2 If you have noticed some paint coming off then stay with it!! It's a momentum thing once it starts coming off it should start coming off quicker! :whistle:
2nd - Sounds as unlikely as the tape thing, but I have had really good luck with just using my thumbnail the scrape it off!! No instructions required I think! :teasing-blah:
Lastly, 92%+ Iso Alcohol - DON't Soak it!! Get a paper towel and wet it then just drap it over the area you are working on and try to rub off some paint every few minutes. If you soak it you run the risk of removing ALL the paint! Actually, I have to back track a little cause I did totally strip one of these & repaint it and I used the alcohol method, but it may be a bit too aggressive for just removing the Tampo printing. :think:
masmojo
Postby Capn Jodi » Thu Nov 07, 2013 4:09 pm
Like the rubbing alky. Also, while doing this a little wine helps the process. Internally applied to slot car addict, of course!
Capn Jodi
Postby mgs75thmeu » Thu Nov 07, 2013 6:57 pm
Scrubbing with 92% will do it but it's going to take the paint too so be ready to spray it. Here are my conversions/creations. All have SCX NASCAR chassis:
mgs75thmeu
Postby OldDogMotorsports » Thu Nov 07, 2013 7:04 pm
I`m with CAP`n JODI on this! :laughing-rolling:
OldDogMotorsports
