Home Racing World • View topic - PUTTING TOGETHER A 0LD TRACK IN A NEW WAY
Postby OL Mike » Fri Mar 14, 2014 10:33 am
Image Image Image
OL Mike
Re: PUTTING TOGETHER 0LD TRACK IN NEW WAY
Postby TuscoTodd » Fri Mar 14, 2014 4:49 pm
Great to see you putting the older track to use Mike! :text-bravo:
Re: PUTTING TOGETHER A 0LD TRACK IN A NEW WAY
Postby gedgeman » Fri Mar 14, 2014 9:41 pm
I have one of the old Hi-Bank Revell sets. I think it is pretty much the coolest bank turn of any home set ever. You will have fun with it Mike.
gedgeman
Postby HomeRacingWorld » Fri Mar 14, 2014 10:02 pm
Nice work Mike. Cool indeed.
Postby ourwayband » Sat Mar 15, 2014 6:12 am
Mike you will love that ol' track.Plus you can run any of your cars on it.Great deal!!
Postby Cjent » Sat Mar 15, 2014 7:19 am
:clap: :clap: :clap: :clap: :clap: :clap: :clap:
Cjent
Postby DHansen » Sat Mar 15, 2014 10:30 am
Great track choice Mike. You can run any scale cars on it from 1/43, 1/32, 1/24. And the stuff is practically indestructible.
DHansen
Postby masmojo » Mon Mar 17, 2014 12:14 pm
Yes, the Revell is great old track, I got rid of mine years ago, before I switched from 1/32 to 1/43, but I kind wish I had it now! I think for 1/43 it would probably be THE ideal 1/32 track to run on! Should not really need run offs except maybe in the tight turns. :text-bravo:
One word of caution and kind of a heads up!; Revell was not designed with todays high mag downforce cars in mind and sometimes the rails can be loose! A little prying/bending of the tabs on the underside of the track can snug down the rails so they don't lift and rub on the bottoms of the cars as they go by! :auto-driving:
masmojo
