Home Racing World • View topic - What Ohm Controller do you use?
Postby Man Machine » Sat Mar 22, 2014 7:04 am
Now I know from my old days of wing car racing you need to set the car and controller for the track type.
I have a Carrera (SP?) 1/43 track for the kids and the controllers are JUNK. So I have a bunch of resistors and Parma parts (Use to make my own back in the late 80's)laying around to make 2 controllers but I only have 4 to .8 ohm resistors.
Are you guys using somewhere between 15 and 45 ohm?
Thanks!
Man Machine
Re: What Ohm Controller do you use?
Postby pfuetze » Sat Mar 22, 2014 8:13 am
45 ohms are a little tricky, they only work good on good running cars, like F1. 60 ohms are better.
The stock Go!controller has a turbo button and 3 wires. The 3rd wire bypasses a resistor in the track power piece. If you want to use parma controllers or others, you need to bypass that resistor in the track power piece.
Peter
Postby Cjent » Sat Mar 22, 2014 9:13 am
Cjent
Postby LloydL » Sat Mar 22, 2014 9:52 am
I have only 45 ohm Parma controllers, wired for brakes, that I use on my Carrera GO and routed tracks.
I do not use traction magnets and,especially on the Carrera GO track, I feel that a 60, or even 70 ohm, controller would make the cars easier to control, so they are on my shopping list!
Regards, Lloyd
LloydL
Postby Dodgefarmer » Sat Mar 22, 2014 11:46 am
I'm using 45's on Go track with Go, SCX, and Dslot. Love the response.
Randy
Dodgefarmer
Postby Datto » Sat Mar 22, 2014 3:37 pm
I have 45Ω, a 60Ω and a 90Ω controllers. I use the 60 most of the time This is on a copper-taped wood track w/ variable voltage. I am no ace driver, it should be noted :violin:
Datto
Postby LloydL » Sat Mar 22, 2014 5:32 pm
Thanks Roland, I was under the impression that by using 2 resistances you lowererd the ohms rating, I want to increase mine. Do you know of any links showing how this is done?
Regards, lloyd
LloydL
Postby pfuetze » Sun Mar 23, 2014 2:10 am
@Chuck - you are right, but that will be for good drivers and well tuned cars, right!
@Lloyd - i made switchable controllers with parallel resistors. My most beloved controllers are the 90 ohm parma eco, switchable to 75 and 60 ohm, than i got 45/35/25 and 15/11/8. Did not need any other.
And yes, controller needs differ from track to track, surface to surface and very much to the personnel preferences.
Postby Man Machine » Mon Mar 24, 2014 10:28 am
wOW! 60 ohm? I used to use those for HO racin.
Looks like I have to order some soon!
Thanks!
Man Machine
