Figured I better get my act in gear, actually had the chassis semi sorted but now I've started on the body. :banana-dance:
My Ninco Jag XK120 is getting the works, new 3D printed chassis, 3D Printed Pod, and all the assorted running gear.
Amato 3D Chassis from Shapeways
CG Slotcars 3D pinted motor pod
M/T Racing 18k motor ( for now )
CB Design insert wheels on all four corners
Paul Gage PGX tires
Slotting Plus Guide Keel.
Chassis is pretty much sorted, needs a few tweaks and weight adjustments once body is ready.
new out of the box body.
stripped of all the pretty stuff.
Body primed and sanding off some bad spots, ready for next coat and then to decide which color I should use. British Racing
Green maybe???? :auto-checkeredflag:
