Car Arrivals/Photos/Test&Tune Process
Older topics that might still have some photos for reference material.
Postby HomeRacingWorld » Fri Jan 04, 2019 10:02 am
A couple of have asked some questions regarding the process when the cars arrive.
*If the model was damaged in shipment, I will contact you personally with photos. I will do my best to repair it.
1. Model(s) will be photographed and each one will have its own web page.
2. Each car will have a "shakedown" test time before race day to make sure it is mechanically sound. During the shakedown we will check that it clears the track, nothing dragging, etc.
If for any reason the car doesn't meet the guidelines, I will contact you directly. We have not had a car in this event yet that did not compete aside from a couple special models that were already known not to be in the event.
3. If during the shakedown or the race, your model is damaged beyond the normal scratches/scuffs that will always occur I will repair to the best of my ability.
*I have all the parts on the Skunkworks wall to repair any mechanical failure. If you lose a gear, motor failure, etc, I feel we should repair it. This even is a special one and I do not want a car not to be raced due simply to a failure. There is NO cost for the replacement parts. These are provided by myself as well as generous support from Slot Car Corner.
Some of these tasks are why I need the entries by the date given. I need time to accomplish the photos and shakedown.
Hope this helps and look forward to seeing the models arrive :dance:
Return to HRW Archives
