Home Racing World • View topic - Dynamic Tongue
Dynamic Tongue
Dynamic Tongue
Postby chappyman66 » Tue Dec 04, 2018 9:06 pm
Re: Dynamic Tongue
Postby mattb » Tue Dec 04, 2018 9:12 pm
So what have you done? Did a scan and created the program? Picture looks good!!
Re: Dynamic Tongue
Postby chappyman66 » Tue Dec 04, 2018 9:57 pm
Nothing quite so advanced.
A much more prosaic caliper and an evening on the computer.
Re: Dynamic Tongue
Postby MrFlippant » Thu Dec 06, 2018 11:21 pm
In many (most) cases, that is the better solution.
MrFlippant
Re: Dynamic Tongue
Postby chappyman66 » Fri Dec 07, 2018 7:34 am
Yup...the "Artin" chassis was reverse engineered the same way over the course of several evenings.
Very frankly, it makes me appreciate a great running 3D printed slot car worth the $120 or so that's asked....there is a LOT of time invested in making a good body and compatible chassis.
Re: Dynamic Tongue
Postby mattb » Wed Dec 12, 2018 1:10 pm
Here are the initial results of a 3D printed frame tongue to fit the Dynamic cast motor mounts from the 60's. Paul Miller took time to measure and design a tongue and used that program to print a couple. I put one together yesterday and gave it a test
Here is the prototype. It may be better to thicken up the guide hole extension to be flush with the bottom of the tongue body and then it will be stronger and can be sanded to give correct guide height. That would eliminate the step shown on the stock tongue. The tongues are upside down in this picture.
Fit was correct and all stock parts worked great.
Lighter and more flexible than a stock tongue. I added 4 Dynamic weights and it settled in the track fine. Usually I put a piece of brass underneath to add weight and improve handling. That is the best way to improve all Dynamic chassis. In this case it would also make it more rigid, although flexiblbility didn't seem to be a problem.
I usually put a spacer between guide post and frame hole to move the guide down in the slot. This is not always needed and depends on front wheel size and chassis setup. I think it might be better to make the bottom of the guide extension flush with the bottom of the tongue. Stock tongues have a small offset to the top. By making it flush on the bottom, it would strengthen the guide extension a bit and it could be sanded to make a step and move the guide upward, if needed.
Here's some pix and Paul can weigh in with more info. I am impressed with the whole process and appreciate Paul taking time to experiment with this. I purposely did three wall shots to see if it would break. It held up OK.
Here is the built up chassis with weights attached.
Here is a brass plate attached as I usually do, which would add weight and rigidity.
Re: Dynamic Tongue
Postby chappyman66 » Wed Dec 12, 2018 1:36 pm
Hi Matt....
Thanks for doing the write up and testing. The pictures are great....I am glad that it fits.
I agree that it will be better to have the mount full height....I just did it this way for fidelity to the original. But it's easy to fix, so I can do that tonight.
For what it's worth I printed at 50% infill so I will try 100% and you can see if those are any better.
Return to 3D Slot Forum
