Home Racing World • View topic - Looking for Pointers in scanning
Postby ccobra » Mon Dec 17, 2018 3:20 pm
I'm trying to find a lazy way to scan models that would be successful. So far it has been hit and miss for me with some working and some not. For example my current challenge looked ok to me after the scan and combining mode:
but then after doing the conversion I get the blob:
Any suggestions?
ccobra
Re: Looking for Pointers in scanning
Postby proxieken » Tue Dec 18, 2018 5:41 am
proxieken
Postby MrFlippant » Tue Dec 18, 2018 11:45 pm
Definitely watch the video. As explained, photogrammetry is still not the best way to create a model. It's OK for organic objects, things that are "bumpy", but not so much for the clean lines of things like cars. If it's a model car, then you'll want to prep it with a matte paint job or something, because shiny things don't work well. In the end, you'll probably need to spend a lot of time tweaking it, anyway.
MrFlippant
Postby HWPSlotCars » Wed Jan 09, 2019 7:45 pm
I was sent a super high resolution professional scan of a famous race car to play around with. It was essentially only useful to serve as a digital "body buck" on which I retopologized from scratch snapping my model to the surface of the scan. It was much faster than trying to correct all the problems inherent with scanning shiny metal and glass objects. My new mesh followed the flow and panel lines of the car, making it much smoother and much easier to edit, modify, and scale as needed to get it down to 1/64th scale. Scanning is just not that good yet for generating reliable meshes. Especially if you're scanning a small object. The percent error is far too great. Here's a side-by-side comparison of a scan vs. retopo/redrawn mesh...
HWPSlotCars
Postby Double Naught » Fri Jan 11, 2019 11:40 am
CCobra, have a look at Meshmixer software for scan repair. I have had some success filling holes and repairing bumps. It’s free and you sculpt with too.
Paul
Double Naught
Return to 3D Slot Forum
