Home Racing World • View topic - F1 proxy Wheel/Tire options.....Update
Re: F1 proxy Wheel/Tire options.....Update
Postby Rleog » Tue Nov 13, 2018 3:11 pm
Thanks again, Chris. It’s reassuring to read this. I had already decided to forego purchasing and preparing another set of rear wheels in order to get slicks with adequate clearance. I’ll be using the NSR F1 20 x 13 tires with shallow grooves remaining on them after truing.
In testing on my track the car subjectively seems to have plenty of rear grip.
Rleog
Postby Brumos RSR » Wed Nov 14, 2018 1:29 am
Chris, feel free to send the slick set to the Brumos RSR garage for a HRW contribution as I need to order a car and get building with all the great info you've provided.
Brumos RSR
Postby GTOking » Wed Dec 05, 2018 12:12 pm
I have chosen CB Design 14x8 F1 front wheels because the F1 cars I own all have wobbly front wheels. I see no hope for the stock wheels. So I have a few tires that fit these 14x8 wheels but when mounted they measure a tick under the minimum width rule of 10.5mm. Any front tire suggestions from the knowledgeable to fit the CB Design 14x8 wheels and comply with the rule or is a tick narrow going to be acceptable? My micrometer reads 9.89mm.
GTOking
Postby chrisguyw » Wed Dec 05, 2018 1:17 pm
chrisguyw
Postby GTOking » Wed Dec 05, 2018 2:01 pm
Thanks Chris. I had previously read your tire/rib mod post. I may try that as a last resort. I'm going to try the Ninco tires on these wheels first.
Thanks again
Ken
GTOking
