Home Racing World • View topic - 2019 Formula 1 Proxy Race - Rules and Registration
Postby Audi1 » Wed Oct 17, 2018 5:18 am
Now that the SCCA Proxy is off and running, it's time to have another look at a Modern Formula 1 Proxy here on HRW.
This will be a bit of an experiment, as these cars are known to be fragile and multiple Rounds at different tracks with different drivers is bound to have an effect on them; particularly the front ends. As a result, I want to take a conservative approach to this proxy; one that's geared to having the same number of cars on the starting grid of the final Round as there was on the starting grid for the first Round.
I want to thank everyone for their input on the "...just noodling...." thread; lots of helpful info and good ideas. So, here's where I think we're heading at this point and there's enough info below in the Rules to open the Registration for this event.
Rules
1. Scalextric Modern Formula 1 cars; those with the slimline IL motor configuration (2005-2017), but I've also heard that there were some slimline cars offered in the second half of 2004; if you have one of those, it's legal, too
2. Spec motors; either the SCC Minnow (18k rpm) or the M/T SL-2 (18k rpm) [Note: if you use the Minnow, then you may well need to add a motor shaft sleeve, as the shaft on the Minnow is 9mm long, whereas the M/T SL-2 is 12.5mm long (stock Scaley for the later F1 models is 12+mm long)]
3. Gearing - open [Note: stock Scaley F1 is 9:27]
4. Body - stock injection molded plastic Scaley F1 / the body must not appear modified on the outside to accommodate crown gears and the like
5. Chassis - stock injection molded Scaley F1l; chassis must be the one that came with the body; no body/chassis switches / the chassis plate must not appear modified on the outside to accommodate crown gears and the like / the rear axle holder uprights may be strengthened by adding styrene, brass, etc.
6. Wheels - nominal 14' wheels, front and rear; may be aftermarket wheels, but not to exceed the width of the front and rear wheels that came stock on the car; wheels must look period for the car and either have appropriate wheel inserts or be an F1 designated after market wheel
7. Tires - rubber only (any commercially available manufacturer) / can be glued, trued and profiled / fronts not less than 10.5mm/not more than 12.5mm wide, rears not wider than 13 mm / front tires may be overcoated to reduce friction
8. Maximum Track; front and rear - not to exceed nominal 61.5mm, outside shoulder to outside shoulder
9. Axles - both the front and rear axles must remain in the same plane as on the stock model; no lowered cars except via tire truing (see minimum clearance spec. below).
10. Front ends can be strengthened with an aluminum or brass tube (more on this later)
11. No-magnets
12. Guides - open; guide adapters like B-nova and Changing-Gearz - OK
13. Weight - not to exceed 85 gms; all weight must be inside or above the chassis platform of the car; no weight hanging from the underside of the chassis. If weight is placed on the chassis platform, but not under the body, it must be painted to match the color of the chassis platform.
14. Clearance - not less than 0.7mm. The crown gear hump on the bottom of the chassis and other sections, such as the digital chip holder, can be sanded flush with the bottom of the chassis plate, or flush with the magnet carrier, whichever is lower
15. Races - 8 Rounds - 4 in the US and 4 in Canada; all on routed wood tracks
16. Number of cars - limited to 24 cars; one car per racer
17. Livery - stock or fantasy
18. Numbers - no duplicate numbers; but duplicate cars with different numbers is fine
19. Racing voltage; up to the discretion of each host track owner, but not to exceed 10V
Registration will be US$25.00 per car. Registration fees will be due by December 1, 2018, via PayPal to: apjarvis@aol.com
Cars will be due at the first track; The River Run, no later than January 31, 2019, shipping to:
Allan Jarvis
46 River Road
Merrimac, MA 01860
USA
That's it! Stay tuned for some slight tweaking changes to the rules towards the end of this week, if needed.
If we get 12 racers then this Proxy will be a go; if not then we'll re-think it at a later date. Maximum of 24 cars; only 1 car per racer.
Registration:
[Racer / Car / year / number]
1. Audi1 / Williams / 2017 / #19 [PAID] [RECEIVED]
2. Radarek / Mercdest / 2014 / #27 [PAID] [RECEIVED]
3. Rleog / Ferrari / TBD / #5 [PAID] [RECEIVED]
4. Chappy / Honda / TBD / #12 [PAID] [RECEIVED]
5. Aloha / McLaren / 2014 / #7 [PAID] [RECEIVED]
6. Beast Lee / Ferrari / 2013 / #13 [PAID] [RECEIVED]
7. BrumosRSR / TBD / TBD / #33 [PAID] [RECEIVED]
8. Steeveew / Williams / TBD / #10 [PAID] [RECEIVED]
9. Manchvegasracer / Red Bull / 2017 / #3 [PAID] [RECEIVED]
10. Midagekid1 / Ferrari / #15 / #15 [PAID] [RECEIVED]
11. Old23 / Renault R24 / 2004 / #23 [PAID][RECEIVED]
12. Chrisguyw / TBD / TBD #17 [PAID] [RECEIVED]
13. GAS41T / Mercedes / 2014 / #44 [PAID] [RECEIVED]
14. Modernslots / Mercedes / TBD / TBD [PAID] [RECEIVED]
15. Mark / TBD / TBD / TBD [PAID]
16. Charley / McLaren Honda / 2017 / #14 [PAID]
17. Arrold / Ferrari / 2017 / #57 [PAID] [RECEIVED]
18. GTOking / McLaren / TBD / #4 [PAID] [RECEIVED]
19. War Eagle River / Renault R18 / 2008 / #5 [PAID] [RECEIVED]
20. AsbestosMcQueen / McLaren MP-4 / 2007 / #87 [PAID] [RECEIVED]
Re: 2019 Formula 1 Proxy Race - Rules and Registration
Postby Radarek » Wed Oct 17, 2018 5:31 am
Oh... why not.... Radarek #27 please.... Renault...
Allan... Williams? ....I don't know... worst team so far this season... :roll: just kidding
Edmonton would like to host if you need us. We are building new track now...
Radarek
Postby SRQSloter » Wed Oct 17, 2018 7:05 am
Stock wheels?
SRQSloter
Postby Audi1 » Wed Oct 17, 2018 7:17 am
Stock plastic or aftermarket plastic or metal; as long as they're 14x8 in the front and 14x13 in the rear and look period-correct for the car.
Postby Z-carfan » Wed Oct 17, 2018 8:10 am
Stock rubber, no urethane correct?
I will enter, Renault (fantasy livery TBD) car # 31 please.
Postby Rleog » Wed Oct 17, 2018 8:33 am
My Ti-22 was abused/trashed at one of the Can Am proxy rounds so I have experience with getting back damaged goods.
Put me down for Ferrari #5, from the Scalextric model C2751, with F2004 embossed on the bottom of the chassis.
Thanks
Rleog
Postby chappy » Wed Oct 17, 2018 9:32 am
Put me down Allan car and number to be determined.
Make Canfield Green the last stop as i will be in Florida from January till the end of March
Postby Audi1 » Wed Oct 17, 2018 10:33 am
Postby Aloha » Wed Oct 17, 2018 10:40 am
I am always willing to support your great events. Please count me in
Aloha
Dale
Aloha
Postby Beast Lee » Wed Oct 17, 2018 10:54 am
Allan...
I'm interested in this one...
McLaren #13 please...
All the best...
Ron...
Beast Lee
Postby Brumos RSR » Wed Oct 17, 2018 12:50 pm
Allan, as I'm trying to resist this and not ask questions or get involved but put me down for the #33. I think I have an incurable disease or I've become something all Father's pray never happens when it comes to proxies.
Brumos RSR
Postby Z-carfan » Wed Oct 17, 2018 1:09 pm
Postby Audi1 » Wed Oct 17, 2018 1:34 pm
Postby steeveew » Wed Oct 17, 2018 1:39 pm
Why not, I'll try it.
Steve
steeveew
Postby chappy » Wed Oct 17, 2018 3:35 pm
Allan i think wheel size may need to be looked at as NSR dont have the required sizes , also the max weight , perhaps should be looked at for a minimum weight.
Just current thoughts
