So, I put the front end on the car, zero grips glued and trued, axle height adjusted, wheels spinning freely. All seems good. With the body attached took it to the track for some time trials. One half second slower than the chassis without front end! Yikes! That's 3 tenths slower than my target and about where chassis 001 is performing with a 19k Spanish King! The car is a bit too loose in the rear end. Not undriveable, but it is costing me precious tenths.
Looking at the car, I notice that there is not much play between body and chassis even though body screws are backed off a good bit. I may need to bore out the holes in the chassis just a tad to get some float. The rear tires are quite meaty and fill the rear wheel wells and while there isn't any body contact it wouldn't hurt to take some more rubber off the tires to lower the profile and cog. So, back to the bench this afternoon. I'm too far into this NSR to abandon it for something else.
