Home Racing World • View topic - 2019 Can-Am spec sheet
Postby Cgyracer » Mon May 06, 2019 10:40 am
Hello, Allan asked me to create a spec sheet for the Can-Am entrants as there has been interest displayed by several individuals. If you can please post your info here on this thread or PM me your info. Thanks!
Name / Number - Cgyracer #10
Country - Canada
Body / Make - Thunderslot McLaren M6A
Chassis - Thunderslot standard chassis
Configuration - Thunderslot sidewinder standard pod
Front Hubs - Thunderslot 14x8 standard hubs
Rear Hubs - Thunderslot 14x10 standard hubs
Front Tire - Slot.it zero grip
Rear Tire - Nsr Supergrip
Gearing - 11/32 standard Thunderslot
Motor - Thunderslot 21.5K Mach
Guide - Thunderslot standard guide
Allan can send me the car weights .
Thanks!
Rob
Cgyracer
Re: Can-Am spec sheet
Postby Aloha » Mon May 06, 2019 11:23 am
Rob
I’ll take a shot at it
#3
Thunderslot (T/S) McLaren White Kit
T/S Stiff Lola Chassis
T/S standard pod
CBD wheels front and rear 15x8
NSR super grips rear
YD ZG front
NSR gearing 11/33
Piranha motor
T/S guide
Hope to finish in top 20
Aloha
Dale
Aloha
Postby BARC 1 » Mon May 06, 2019 11:56 am
BARC Ferrari 350 # 20
Chassis scratchbuilt Brass with angle winder pod
CB wheels
NSR ultragrips
30 K Shark motor
Slotting plus guide
Scratchbuilt cast resin body
Hope not to be last.
Postby Brumos RSR » Mon May 06, 2019 12:17 pm
#33 Brumos RSR
USA
Thunderslot medium chassis
Thunderslot Stiff pod medium springs on the rear only
CBD front wheels Thunderslot Rear
NSR ZERO GRIPS/ Thunderslot on the rear
11/32 NSR gearing
25k piranha
Thunderslot guide
Hope to finish in the top 21, Aloha is usually ahead of me.
Brumos RSR
Postby F1Fan » Mon May 06, 2019 12:43 pm
Name / Number - F1Fan #7
Country - Canada
Body / Make - Thunderslot Lola
Chassis - Plafit
Configuration - SW
Front Hubs - CB design 15x8
Rear Hubs - Slot it 15x10
Rear Tire - NSR Supergrip
Gearing - 12/35 NSR
Motor - Scaleauto 25k
Guide - Scaleauto
F1Fan
Postby GT6 » Mon May 06, 2019 12:57 pm
GT6 #4
Canada
Body: Thunder Slot McLaren M6A
Chassis: Thunder Slot McLaren M6A (no modification except 10 gm weight added in front of motor)
Configuration: stock Thunder Slot sidewinder pod
Front wheels: stock Thunder Slot plastic 15 x 9
Rear wheels: stock Thunder Slot alloy 15 x 10
Front tires: stock Thunder Slot Classic Hard
Rear tires: NSR Supergrips
Motor: Thunder Slot Mach 21 FC130 (stock 21.5K rpm)
Gearing: Thunder Slot 32/11 (stock)
Guide: stock Thunder Slot
expectations: que sera, sera.
cheers
Scott
GT6
Postby wanabgts » Mon May 06, 2019 1:51 pm
Name / Number - WANABGTS #18
Country - USA
Body / Make - Slot.it M8D
Chassis - Standard Slot.it
Configuration - Slot.it .5 offset sidewinder pod
Front Hubs - Slot.it 15x8
Rear Hubs - Thunderslot 14.3x10
Front Tire - Slot.it w/CA
Rear Tire - Thunderslot tyr004 Racing slick
Gearing - 11/32 standard Slot.it
Motor - NSR Shark 22
Guide - Professor Motor
I think the rear tires are probably the main disadvantage of the car in the long haul, hoping to hang with a couple veterans on my first proxy is all!
Zack
wanabgts
Postby Courtney s » Mon May 06, 2019 2:27 pm
Name Number Courtney s #8
USA
Body Slot it Mclaren M8D
Chassis Plafit
Configuration Anglewinder
Front Hubs Parma
Rear Hubs JK
Front Tire Parma
Rear Tire NSR Supers
Motor Professor Motor 25k BB
Gears JK 12/37
Guide Red Fox
Per my scale 91g
First ever proxy i have no expectations but I'm excited
Courtney s
Postby Audi1 » Mon May 06, 2019 2:45 pm
Thanks for getting this started, Rob. I'll send you an Excel file with the results of the tech inspection; please PM me your email address, thanks.
Name / Number - Audi1 / #52
Country - USA
Body / Make - Thunderslot Lola T-70 S
Configuration - Thunderslot sidewinder hard pod
Front Hubs - Thunderslot 14x8 standard plastic
Rear Hubs - Thunderslot 14x11 standard aluminum
Front Tire - Thunderslot stock front rubber
Rear Tire - Thunderslot stock rear rubber
Gearing - 11/30 NSR
Re: 2019 Can-Am spec sheet
Postby bov » Mon May 06, 2019 4:58 pm
Welcome to the Dept of "Let's Try Something Different" ( ! )....
The ZepMobile #12:
slot.it Macca M8D
more or less std slot.it chassis
slot.it 29k Red motor ( ! )
11/36 gearing
Sideways Rear Tires ( ! ) on CBD 15 x 10s
About 91g net weight..... ( ! )
Once again, it's probably gunna need "A Whole Lotta Love", or it'll be "Dazed and Confused"......
bov
Postby wanabgts » Mon May 06, 2019 5:18 pm
wanabgts
Postby arroldn » Mon May 06, 2019 6:41 pm
arroldn /21
Country - USA
Rear Tire - NSR Super Grip Rubber
Gearing - 11/32 Standard
Weight - Standard plus 7 grams should be about 68.7 grams
arroldn
Postby steeveew » Mon May 06, 2019 6:57 pm
Steevee W : 65
Country : USA
Body make : Thunderslot Lola
Chassis/pod: Thunderslot stiff
Configuration: Side winder
Font hubs: Thunderslot
Rear hubs: Slot it
Front tire: Thunderslot
Rear tire : Thunderslot
Gearing: 11/32
Motor : Piranha 25k w b/b
Guide : Thunderslot
Weight : 1/4 oz added
Steve
steeveew
Postby Rleog » Mon May 06, 2019 7:16 pm
Name / Number - Rleog / 66
Country - USA
Body / Make - Chaparral 2J / CGSlotCars
Chassis - CGSlotCars Chaparral 2J chassis and pod
Configuration - Slightly angled sidewinder
Front Hubs - CB Design 15 x 8 insert
Rear Hubs - CB Design 15 x 10, 5 spoke racing
Rear Tire - NSR Ultragrip 20 x 12
Gearing - Slot.it 12:32, 1 : 2.67
Motor - CGSlotCars ~21.5 K stock motor
Guide - Slot.it CH85
Weight - 84.4 g
Rleog
Postby gascarnut » Mon May 06, 2019 7:31 pm
Name / Number - Gascarnut / #76
Country - USA
Body / Make - Ferrari 612 / DArt Hobbies (modified)
Chassis - Scratch built brass and wire
Configuration - 8 degree anglewinder
Front Hubs - Samson Classics
Rear Hubs - BWA
Front Tire - Samson Classics
Gearing - 64DP, 11:35
Motor - Piranha 25k
Guide - ScakeAuto
Weight - 103 grams
gascarnut
Return to 2019 Can-Am Proxy
