Home Racing World • View topic - 2019 HRW Hole Shot Nationals!
The PREMIER Slot Car Drag Racing Event!
Forum rules
[url=http://www.homeracingworld.us/viewtopic.php?f=78&t=20296][/url]
Re: 2019 HRW Hole Shot Nationals!
Postby nhdungeonracer » Sat Feb 09, 2019 3:14 pm
Postby teamwild » Sat Feb 09, 2019 7:40 pm
I'll send something in 1/24 scale, no idea what at this point.. I'm sure Dickie will have a big box to send :banana-dance:
Matt :music-rockout:
teamwild
Postby TuscoTodd » Sun Feb 10, 2019 8:26 am
Matt - glad to have you aboard! Will add you to the list!
:handgestures-thumbup:
Postby Ky.Slot Racer » Wed Feb 20, 2019 8:05 am
I`m in, 1-32 Pre '90 Hot Rod 1968 dodge charger :text-thankyouyellow:
Ky.Slot Racer
HRW Master Modeler
Postby TuscoTodd » Wed Feb 20, 2019 9:36 am
Mark - glad to have you join the action! Participant list updated!
Look forward to seeing your build!
Postby Foamy » Sat Feb 23, 2019 12:17 am
Are 3D printed bodies ok to use?
Foamy
Postby TuscoTodd » Sat Feb 23, 2019 6:55 am
Postby Foamy » Mon Feb 25, 2019 12:02 pm
Well, I can start the party with a '63 Vette in 1/32 Hot Rod class as I have all the bits to make it.
Question 1, is the track a routed wood one or plastic?
Question 2, what is the braid depth or rail height?
Foamy
Postby TuscoTodd » Mon Feb 25, 2019 2:06 pm
Postby BARC 1 » Tue Feb 26, 2019 5:00 pm
My entry will be a 66 Mustang conventional Gasser.
Just built a chassis. No idea what works as this kind of racing is totally new to me. Quickest to the end I guess. Seems simple enough, but I bet it isn't
Postby nhdungeonracer » Tue Feb 26, 2019 8:44 pm
Dan, it's not a whole lot different setting up a drag car than a road racing car unless you're adding a drop arm. Even then, the basic tricks apply. Biggest thing is make sure the guide is straight, not crooked so it rubs the side of the slot.
For the 1st race at Todd's, 1/32 cars should plan on using a low gear ratio somewhere around (2.50-2.80 to 1) if using tires around .9" tall. This is based on the top cars from a couple years back.
Postby TuscoTodd » Wed Feb 27, 2019 9:30 am
Thank you for the update on the car - I will update the spreadsheet!
As Dickie has mentioned, for the 55' strip here at Mark's - taller geared cars (2.xx) typically overtook the shorter geared (3.xx) cars in the second half of the track - so 2.xx gearing is your friend here! :)
Postby dw5555 » Wed Feb 27, 2019 11:04 am
[quote="nhdungeonracer"][/quote]I did receive the other one of Ronny's. So Harry's RRRevolution project will have a running mate come July... :D
Image[quote]
I fully expect to seen Jungle Pam lining him up!
dw5555
Postby nhdungeonracer » Wed Feb 27, 2019 4:49 pm
Postby BARC 1 » Thu Feb 28, 2019 11:09 pm
Well I guess I will enter in the wheels up category. During testing I have the wheels lifting the 1/2 inch required on my 66 Mustang Gasser.
With only 12 feet of strait, I don't really know how fast this is. It lifts the wheels, that is all I know for sure.
Return to HRW HOLESHOT NATIONALS!
