Home Racing World • View topic - Hot wheel Porsche LH in resin
PostPosted: Sun Mar 17, 2019 11:35 am
by Ky.Slot Racer
made to mount to a AFX or AW mag trac chassis with 1 screw.
Re: Hot wheel Porsche LH in resin
PostPosted: Sun Mar 17, 2019 5:29 pm
by sadco racing
Great job on this Mark, you got talent brother!
PostPosted: Sun Mar 17, 2019 7:16 pm
by ourwayband
Man she just looks fast!
Great job..
PostPosted: Mon Mar 18, 2019 5:53 pm
by noddaz
I have that diecast! What a great looking resin cast! Are you going to paint it in Gulf colors?
Scott
PostPosted: Mon Mar 18, 2019 6:00 pm
by Norman
Nicely done, Mark!
Yes, Gulf colors would look perfect on that car!
PostPosted: Mon Mar 18, 2019 7:11 pm
by Ky.Slot Racer
Actually this is a dummy cast, so i can work on a few things, remove window areas. Ppen vents, add vents, then smooth the body a bit more and recast it. Then i can mold clear windows as i build.
PostPosted: Thu Apr 11, 2019 12:42 pm
by Ky.Slot Racer
changed direction a bit on this, as going with the AFX 1.5 mega g plus chassis rather than the AW xtrac.
This is my test mule for the body mounting, trimming for tire clearances.
and the 1st 3 paint jobs: These all are from the second mold and casting, so the head light buckets have been filled with epoxy.
This is the 3rd casting, this time with the headlight buckets removed, and castings also made for clear glass/headlight lenses, and a motor detail part.
PostPosted: Thu Apr 11, 2019 3:47 pm
NOW I understand the transition! You have conquered 1/24th and 1/32nd better than anyone, and now you are going to conquer HO! PLEEEEEZE don't go 1/43rd on us. The earth's axis could shift.
PostPosted: Thu Apr 11, 2019 7:00 pm
by ourwayband
Those look GREAT!!!
PostPosted: Tue Apr 16, 2019 8:52 am
by padirtfan
Mark, You never cease to amaze me! That is mighty fine work.
PostPosted: Tue Apr 16, 2019 11:04 am
by Ky.Slot Racer
finally getting the clear parts to a quality I am happy with.
PostPosted: Tue Apr 16, 2019 11:06 am
by MrAdept
How do you get the clear parts so clear?
Like crystal!
Mark
PostPosted: Tue Apr 16, 2019 11:24 am
by Ky.Slot Racer
