I've been trying multiple layouts (for months) until I came out with something I really like enough to go permanent
Many people might remember my older 3 lanes track that I had before , when I took it apart I was stock with lots of single track lane so I decided to take 2 single lane & clued it (hot glue) together to make back to a 2 lanes track again
Here some pictures...
I use 2x 4"1/2 track to hold the single track together & masking tape so that the glue doesn't go trough the track & glue it to the table...
Turned it upside down & put the glue
Glue dry & tape removed
Once I decided what layout I wanted I started to tight the track joints by using a small flat screw drivers so I can get a better contact all over the layout
Cut some tracks to get the length needed for the layout...
Before putting back the rails on the track you have to make it straight again with long nose pliers
Put back the rails & cut the extras rails out
Next part 2
Mikey
