What are the resistors(?) For?
Postby Hotrodbob » Wed Dec 30, 2015 2:11 pm
I see what I think are resistors on the motors of many cars. I have just cut them off, but I'm curious as to what they really are and what they are actually for? Should I leave them on? Borrowed a pic for a Carrera 57 Chevy to show what I'm looking at. Also, what is that circuit board on the Carrera chassis for? Leave it or loose it?
Hotrodbob
Re: What are the resistors(?) For?
Postby dw5555 » Wed Dec 30, 2015 2:22 pm
I believe the resistors are for TV interference. The circuit board is for the directional switch on the bottom. If you don't plan on running in the opposite direction take it out and just plug in the motor to brush wiring and go.
Dave
dw5555
Postby MrAdept » Wed Dec 30, 2015 2:44 pm
The components on the motor are capacitors and are there to cut electrical noise generated by the motor turning from interfering with your analog TV...
If they were missing you probably wouldn't notice.
Mark
MrAdept
Postby Hotrodbob » Wed Dec 30, 2015 2:55 pm
I thought I had heard that someplace, but was not sure. If I'm racing, I'm not watching TV so, no harm no foul... Thanks guys..
Hotrodbob
Postby Nor Cal Mike » Wed Dec 30, 2015 3:17 pm
I'm not familiar with Carrera digital but in the case of Scalextric, these are required to isolate the digital chip from static interference.
Nor Cal Mike
Postby buspor63 » Wed Dec 30, 2015 4:17 pm
I run Carrera digital and I don't use those after a motor swap. We run all mixes of motors together without problems. If you're not swapping a motor, I wouldn't go to the trouble of removing them.
buspor63
Postby Lenny Broke » Wed Dec 30, 2015 4:38 pm
They are suppressors, to filter out interferance to TV and radio. They are a requirement in some countries.
Lenny Broke
Postby Hotrodbob » Mon Jan 04, 2016 1:04 am
Thanks again for the clarification.
Hotrodbob
