Carrera 917K replacement 12v motor
1/24th Scale Slot Car Forum
"Home Of The Big Ones!"
Postby Dangermouse » Fri Jan 25, 2013 5:41 am
There was a topic on putting a 12v motor in the Carrera 917k
It seems the closest size for these is an FC-280 or Fk-280 motor.
I have done a bit of hunting around and if you search eBay for FC-280 motor you will find some possible options for a around $6 a motor. I can't find any that are rated over 12000rpm at 12v so the search will continue.
You can use the Autoart 1/24 motor the Autoart website was showing them out of stock
Paul Gage has an article on it at the old site
http://homeracingworld.yuku.com/topic/2 ... 911?page=1
Not quite sure how much detail is needed for this conversion. It is simply put "swap the pinion, transfer the wiring, drop the motor cover on top of the new motor, torque the screws, connect the wires, quick test, install the body" and then go kill some Scaleauto 997's! Okay, there can certainly be more, but that is a good starting point. In the pics below you can see the chassis stripped down, the old and the new motors side by side, and the empty motor housing. I just place the motor in the bottom of the chassis and drop the cover into place. The cover holds the motor securely in place and the gear lash has been perfect on every installation so far (997, C6R, F575, 2 x BTM Cheetahs, and a GT-40). I order my motors from "AutoArt Collections" website and they are delivered from a California address, the web address is listed on this topic already.
If any of you are interested, the official size of these motors is FC-280. While a few thousand are made for slot cars, millions of them are power window and door lock motors. They can be had for $1.00 to $3.00 at auto surplus outlets. Haven't found one that works well enough as a slot car motor, however the search continues and AutoArt motors are not really that much more money.
The Autoart motor is definitely rated higher than 12k rpm
If anyone can recommend a motor that would be appreciated
cheers
David
Dangermouse
Re: Carrera 917K replacement 12v motor
Postby redlynr » Fri Jan 25, 2013 9:52 am
You can get the Autoart one from Electric Dreams...
http://www.electricdreams.com/Shop/auto ... 12809.html
redlynr
Postby Dangermouse » Fri Jan 25, 2013 10:14 pm
I ordered some from them this morning
cheers
DM
Dangermouse
Postby ddyke » Sat Jan 26, 2013 5:50 am
Since I do not play in the 1/24 world, these may work:
FC-280PT-22125
RC-280SA-20120
PC-280-20125
We have used some of their motors before (http://store.kysanelectronics.com/servl ... s=d007054a) and have list of what we like but have not ordered their 280 motors before. Their motors have always had more torque than their spec sheet said. As always CAVEAT EMPTOR!
ddyke
Postby Dangermouse » Sat Jan 26, 2013 7:45 am
This one looks like the pick of them RC-280SA-20120
http://store.kysanelectronics.com/servl ... 120/Detail
DM
Dangermouse
Postby lebhobbies » Sat Jan 26, 2013 9:56 am
Try a commercial slot track motor like a 16 D from Parma.
lebhobbies
Postby ddyke » Sat Jan 26, 2013 1:03 pm
They have a $100 minimum sale (unless they changed recently). You may want other motors. Here is what we have tested: http://cincyslotrods.yuku.com/topic/144 ... QQoIGdKaPU
ddyke
Postby 351c » Tue Feb 12, 2013 3:14 pm
I ordered 2 auto art motors for my 1/24 carrera cars much faster and way more fun.
351c
Return to HRW 1/24 Scale
