La Carrera Panamericana Rnd 3 Cornerstone Raceway MA RESULTS
Re: La Carrera Panamericana Round 3 Cornerstone Raceway MA
Postby JT Previa » Sat Feb 25, 2017 8:48 am
The red car number 31 Drive slow but handles great but I can use heavy throttle in the corners wide-open on the straightaways fun to drive
JT Previa
Postby JT Previa » Sat Feb 25, 2017 8:55 am
Fun car, fast, but loosens up toward the end of heat.
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:01 am
Mad Dog Margarita. The Federales might chase this one.
Fast, smooth, tail is loose, seems to binds a bit internally.
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:06 am
this elegant Vette was very drivable. just repaired a rear wheel before this heat.
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:12 am
The 12 snuck past the 53. Perhaps under tired, the 12 was tail happy.
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:13 am
Heat finished in qualifying order, except 53 dropped back.
JT Previa
Postby Audi1 » Sat Feb 25, 2017 9:14 am
Looks good!
Postby JT Previa » Sat Feb 25, 2017 9:16 am
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:17 am
The air is heating up here at Cornerstone.
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:18 am
Next Heat!
JT Previa
Postby Audi1 » Sat Feb 25, 2017 9:19 am
You're lending a new meaning to the term "live streaming".......! Great job so far - thanks!
Postby JT Previa » Sat Feb 25, 2017 9:25 am
The red speedster musta had too much tequila it was very tippy in the corners otherwise fun, like many things with too much liquor.
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:30 am
I got to drive the 77 and had better luck: smooth and. Fast, but would roll at the edge.
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:31 am
JT Previa
Postby JT Previa » Sat Feb 25, 2017 9:37 am
259 fast, but needs more slide: tends to snap roll at limit. Good looking car. Floppy front wheels don't help this.
JT Previa
Return to La Carrera Panamericana-2 Fun Run - 2016
